bluetop turbo vs gtz turbo
Postby bluemaumau » Wed Jan 04, 2006 12:00 pm
as stated. the pros and cons of each.
obviously bluetops are 20xs easier to get hold of than gzes, and cheaper but what about max hp, boost ,etc what mods need to be done to get a bluetop to run a turbo application?
would a bluetop drop strait into a 93 ae101 4afe wagon?
thanks in advance
Postby TRD001 » Wed Jan 04, 2006 12:42 pm
why not go a B/T 20V Turbo?
The big secret in life is that there is no big secret. Whatever your goal, you can get there if you're willing to work.
TRD001
Postby bluemaumau » Wed Jan 04, 2006 12:46 pm
cuz the internals are shit. comp is too high.
Postby Mr Revhead » Wed Jan 04, 2006 12:53 pm
mods: pretty much the same
hp: not much difference
the difference is in how long each will last! :lol:
Postby Low_Aa63 » Wed Jan 04, 2006 12:57 pm
is blue top turbo going into a rwd? ie dx 85/86, im sure then the blue top turbo will surely win the race!
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby Alycia » Wed Jan 04, 2006 12:58 pm
bluemaumau wrote:cuz the internals are sh*t. comp is too high.
What a pathetic thing to say :roll:
Bunghole :!:
Alycia
Postby Mr Revhead » Wed Jan 04, 2006 1:02 pm
hmmm nope doesnt look rwd to me.
the GZE would the one that could make the most peak hp and live.
as its got the forged pistons. while you could prob get a similar amount frm a bluetop, id would die long before the GZE
Postby bluemaumau » Wed Jan 04, 2006 1:05 pm
Bunghole :!:
ok then the internals are NICE they run beautifully on a N/A car, but as the post is about turbo applications that is the truth.
revhead - im taking the gtz will last longer. - but the gtz can handle more boost (+20psi) cant it? were as bluey - like 16psi max? correct me :roll:
Postby Mr Revhead » Wed Jan 04, 2006 1:10 pm
sounds about right
its all in the tuning
Postby Drifter4ag » Wed Jan 04, 2006 1:59 pm
Pound for pound ..small crank vs large crank makes more power from our dyno runs.
If it were me and I wanted to experiment i would go 7rib block bluetop crank with shot peined rods and custom JE pistons or something for it
.. around 8.9:1 and see how it goes
but i would go for a GZE if you have the money
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Mr Revhead » Wed Jan 04, 2006 2:08 pm
by how much?
the only prob with the 40mm crank is the 18mm gudgeons. JE pistons cost a bit. maybe machining out the rods to take the 20mm pins and using ze pistons.
guess it comes down to $$ vs what you want.
Postby Drifter4ag » Wed Jan 04, 2006 2:13 pm
yeah .. people with similar setups are usually abour 3-5kw@wheels down per pound of boost ... but it does depend on the build of engine and the tuner ..
my 8.0:1 ze is making 148kw on 11psi ... which is on par with my crazy bluetop :D once it hits 15psi ... should have it up to about 20 or so for Rotor nats
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby matt dunn » Wed Jan 04, 2006 10:12 pm
Bunghole :!:
Yes, how can you say things like that.
Everyone know's it true, but your not meant to say!! :D
