WOF failure for a split engine mount?
Postby Wildcard » Tue Jan 03, 2006 12:14 pm
My girlfriends Lantis has a small split in the front engine mount - it failed a WOF at VTNZ based on this and a few other bits and pieces, is this actually part of the WOF requirements? The mount is split but certainly not enough to allow the engine to move - I just thought it was a little ... excessive.
Wildcard
Toyspeed Founder
Postby l1ttle_d3vil » Tue Jan 03, 2006 1:01 pm
a split mount may not allow the engine to move now but it definitely will once it breaks in half... :lol:
Postby Malcolm » Tue Jan 03, 2006 1:28 pm
VTNZ= anal..
The corsa failed at VTNZ on something similar, the engine mount bracket thing is held on by 2 big bolts in the middle, and then there's a little tab off to the side and that didn't have a bolt in it. I wonder if they have instructions to be very scrutinous of engine mounts; maybe there have been a number of engines falling out of cars lately...
Postby Adydas » Tue Jan 03, 2006 1:30 pm
Sounds as dumb as shocks cant you pass a totally wasted shock that would barly keep you on the road as long as its not leaking oil visablly.
Adydas
Postby BZG Wagon » Tue Jan 03, 2006 1:43 pm
Adydas wrote:Sounds as dumb as shocks cant you pass a totally wasted shock that would barly keep you on the road as long as its not leaking oil visablly.
Thats really funny. My rear shocks have absolutely had it and they still fly through a warrant.
As for the engine mount, you would want that fixed regardless. They are not hard to fix and it would be well worth it. Everytime you put load on the engine / gearbox its going to start making it worse, and eventually it will start putting strain on the other mounts.
BZG Wagon
Postby CozmoNz » Tue Jan 03, 2006 1:57 pm
yeh, might as well pay for it now rather than down the track when money might be tighter....
Rayne For President!
CozmoNz
Postby Boosted_162 » Tue Jan 03, 2006 2:52 pm
My shocks were so rooted they wouldnt come back up, yet it managed to get complianced with them, and clean WOFs etc :? There was no leaking oil so means they are sweet?
Re: WOF failure for a split engine mount?
Postby BZG Wagon » Tue Jan 03, 2006 3:45 pm
Wildcard wrote: The mount is split but certainly not enough to allow the engine to move - I just thought it was a little ... excessive.
How do you know the engine doesnt move? Just because you cant move it doesnt nessesarilly mean it doesnt move. The only way you would see it move would be under engine load or you might be able to hear it when you engage the clutch.
BZG Wagon
Postby 3T-Rona » Tue Jan 03, 2006 4:13 pm
hahaha the rear shocks in my L200 passed a warrant no questions asked but the rear spring shackle bushes and shock bushes needed replacing so after work i drove onto the pit and with out jacking it removed my shocks and changed the bushes, the shocks r so absolutly rooted its nt funny there was no pressure on them at all and i could compress and extend them with extreme ease..... shows how good warrant checks really are
3T-Rona
Postby deaf_rattle » Tue Jan 03, 2006 5:12 pm
sounds like a weekend job for team mechanics!!
let me know if you need a hand ben.
I just paid for 2 engine mounts for my fxgt $206 for the pair.
Postby Nuty|Mike » Wed Jan 04, 2006 11:07 am
post up the chassis number benjamin i may have wat u need in stock it may be very cheap and it may even get delivered for free pending a free bottle of wine or two ;)
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby Mr Revhead » Wed Jan 04, 2006 11:11 am
deaf_rattle wrote:I just paid for 2 engine mounts for my fxgt $206 for the pair.
8O
yeah busted engine mounts = fail.
Postby deaf_rattle » Wed Jan 04, 2006 2:06 pm
yeah, didnt really have the money to spend on mounts, but couldnt see the point of putting the stuffed ones back in only to have to replace them for the wof in a couple of months anyway.
Postby Adydas » Wed Jan 04, 2006 2:38 pm
Bingo as long as its not leaking oil to them its fine and passable.
Adydas
Postby Mr Revhead » Wed Jan 04, 2006 2:41 pm
they can and do fail it if they think its too soft.....
Postby fivebob » Wed Jan 04, 2006 2:45 pm
Mr Revhead wrote:they can and do fail it if they think its too soft.....
And also for no good reason at all, like my last WOF on the Caldina, reads "Left rear shock absorber worn out". WTF???? Any fool could see that the shock was fine, and if they'd bothered to check, instead of assuming the noise they heard was a stuffed shock, they would have found that the problem was a faulty CV joint :?
Postby Mr Revhead » Wed Jan 04, 2006 2:48 pm
but that would require bending over or worse, getting under the car 8O
its painfully obvious the WOF system in NZ is woefully lacking
however the other side of the coin is how do you fix it?
to do a proper and fair inspection will cost a lot more....
however its also plain to see that a lot of the discrepancies are due to ineptitude and/or cantbefuctitis.
thats my quota of big words for this year 8O
Postby CozmoNz » Wed Jan 04, 2006 2:49 pm
whats TOO soft? Because some of those old 80's coronas / cressies etc are like boats.. and still warrentable. (ive driven 4wd's with MUCH better handeling)
CozmoNz
Postby Wildcard » Wed Jan 04, 2006 4:58 pm
Actually never mind, as an interim step she took it to the local garage today and they passed it :roll:
Wildcard
Toyspeed Founder
Postby EVLGTZ » Wed Jan 04, 2006 5:05 pm
passed at the local garage but failed at VTNZ?
Shouldn't that have been picked up on the computer system somehow??
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
