When it comes to cars what can you do / have you done.
How much work do you / have you done.
Check Book Racer. ( Pay for everything to be fitted and installed )
18
8%
Basic Installer, Can fit own sounds and minor mods, Ie pod filter.
23
10%
Engine swapper / Gearbox changer / Clutch fitter
90
41%
Replace Internal parts within Gearbox and or Engine, Swap pistons play and or cams / cam timing etc.
35
16%
Rebuilt a motor and fitted it into a car it dont belong in, Modified things and generally are a mechanic or close enough to.
54
25%
Total votes : 220
Postby Adydas » Tue Jan 17, 2006 8:30 pm
Simple intrest poll, Please be honest as votes will only lie to your self.
Any bickering or negative comments will result in a lock by me and i am intrested to know the stats from this.
So please IF you REALLY have to comment keep it clean.
I can only assume your vote means you can also do the stuff below to.
I assume mates gave a hand as no one can carry a gearbox alone unless
Adydas
Postby FrEsH » Tue Jan 17, 2006 8:32 pm
standard installer i'd say as i haven't tried to chagne a clutch/engine etc yet...haven't had to :P
FrEsH
Postby 2LTR Rona » Tue Jan 17, 2006 8:37 pm
Engine swapper / Gearbox changer / Clutch fitter I would say moving more towards the other two i.e. currently rebuilding my Capri from the ground up (with help here and there) and will then move on to the KE25 with the engine swap 8)
2002 Altezza, 1974 KE25
2LTR Rona
Postby Adydas » Tue Jan 17, 2006 8:50 pm
we all are a talaented bunch of buggers arnt we :p
Adydas
Postby MINTFX » Tue Jan 17, 2006 8:54 pm
Standard installer here, but I have replaced my own clutch, fuel pump and other crap. I could probly do an engine swap with the right tools and directions. I have pulled a motor apart aswell, didnt put it back together though as it had a huge hole in the side of the block :lol:
MINTFX
Postby Emperor » Tue Jan 17, 2006 8:56 pm
I'm inbetween Basic and Standard. I can do my own sounds, pod filters, oil changes, etc
Though I do admit I ask for help on most stuff.
Emperor
Postby supradave » Tue Jan 17, 2006 9:01 pm
When it comes to my car im not to bad but give me basically anything else, especially different make im lost. and dont get me started on subaru's 8O lol
ADMIN EDIT: oversized image removed - see forum rules for acceptable image sizes
supradave
Postby Malcolm » Tue Jan 17, 2006 9:03 pm
as far as my own cars go, I know them almost inside out and do almost everything myself (except machine work - since I don't have the right machines, and wheel alignments, because I don't have an alignment rig :) )
If I was to perhaps have someone throw a 2005 Audi at me or something, I think I'd be fairly lost...
Postby RomanV » Tue Jan 17, 2006 9:32 pm
All_Fours wrote:
If I was to perhaps have someone throw a 2005 Audi at me or something, I think I'd be fairly squashed
Corrected! 8O
I can do a few things, but Im definitely not at the same level as someone like Malcom or Vvega... Much respect. 8)
Im getting there though, still learning new things all of the time. :)
Postby Dell'Orto » Tue Jan 17, 2006 9:41 pm
I can do most things myself...have done engine builds (nothing particularly high tech, 12A 6port would be about the trickiest). Done engine, clutch, gearbox and diff changes.
Only things I can't do are similar to Malcolm...and fabrication, cause I dont have a welder :cry:[/b]
Postby Malcolm » Tue Jan 17, 2006 9:48 pm
RomanV wrote:
All_Fours wrote:
If I was to perhaps have someone throw a 2005 Audi at me or something, I think it would ricochet off my manly chest and land in a quiverring heap in the corner!
Corrected! 8O
Double-corrected! :wink:
Postby V8MOFO » Tue Jan 17, 2006 10:05 pm
I can install I.C.E and change a tyre. 8)
I'm the MAN.
Anger is seldom without argument but seldom with a good one.
Image Fact of the day: I have only updated my fact of the day on time, Three times.
V8MOFO
Postby Santa'sBoostinSleigh » Tue Jan 17, 2006 10:25 pm
currently im an installer, but with my racecar im moving towards engine swap!
a few more tools and a bit of guidance and i'll be there!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Alex B » Tue Jan 17, 2006 10:33 pm
On the low side of 'Engine swapper / Gearbox changer / Clutch fitter' if that makes sence.
Postby vvega » Tue Jan 17, 2006 10:36 pm
im a cheque book racer :lol: :roll: 8O
vvega
Postby 3VLTOY » Tue Jan 17, 2006 11:11 pm
Done an engine swap and manuel conversion but did have a friend there teaching me as i went.
Brake pads, oil change etc. are a piece of piss to do on my own.
Prefer to buy the parts and do it on my own or have someone showing me how to do new things :lol: :lol:
3VLTOY
Postby Brick » Tue Jan 17, 2006 11:54 pm
done clutch, head gasket, taken engine apart and rebuilt it with guidance, brakes and other minor things
Brick
I know Kung Fu
Postby Boosted_162 » Wed Jan 18, 2006 12:44 am
I have no problems putting things where they are designed to go, eg swap a gearbox etc. But when it comes to putting things where they arent designed to go (aka vvega and his 1UZ AW11) i get lost.
Postby DJ » Wed Jan 18, 2006 7:26 am
Have a guess...
DJ
Postby EVL GSXR » Wed Jan 18, 2006 7:43 am
DJ wrote:Have a guess...
:D :D :D
I put Basic and Standard..
Own Stereo, Brake Pads, Filters, Oil Changes, Boost Controllers etc etc
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Return to Polls
