Mr Revhead wrote:hang on a minutean reach 120 in second with the fe box, only 105 with the ge box
wtf. how many revs u doing![]()
Only 7800RPM
quinny wrote:THE LOOM
i waited 7 months for the only guy in wgtn who was keen enough to do it.
ten seconds down the road tho i felt hatred no more! cost me 1100 and 4500 all up but worth every cent, good being able to rev them off the FE's tacho too.
20v_rollaboy wrote:quinny wrote:THE LOOM
Sooo much!
Cost me $800 for donor car, done the engine swap myself, and me and a very good friend done the wiring with the help of a manual
quinny wrote:the wof outfit tried to nail me for my blacktop but lost cos i used the donor caribs front brakes as well (bout 5mm thicker) so no cert was required and they even had to note it down on the wof sheet that is was all legit
ee904age wrote:quinny wrote:the wof outfit tried to nail me for my blacktop but lost cos i used the donor caribs front brakes as well (bout 5mm thicker) so no cert was required and they even had to note it down on the wof sheet that is was all legit
Something smells fishy...
Im sure somebody will correct me if wrong, but wouldnt changing the front brakes require a cert itself let alone the engine swap??
So in reality you need a cert for both the engine swap AND the brake swap??
quinny wrote:ee904age wrote:quinny wrote:the wof outfit tried to nail me for my blacktop but lost cos i used the donor caribs front brakes as well (bout 5mm thicker) so no cert was required and they even had to note it down on the wof sheet that is was all legit
NO FISH BRO, the garage hate me and consulted wgtns main certifier who confirmed his services were not required in this case. The bigger front discs with abs hubs (no ABS on my car) and disc rear end are diect bolt in upgrades. no modifications no problem. i fear the glory of rorting the system will come to an end next wof as i now have tein coilovers and braided lines installed. they may have to take a couple of days off while the sh*t std struts and lines make a quick appearance
scribble wrote:Hmm, but didn't AE101's come with the silvertop, just not the wagon version?
20v_rollaboy wrote:but who these days lives by the letter of the law?
