Testing has shown the smaller the engine, the higher the sustainable boost. If a 3.5-liter engine is running 24v, boost will peak at 10 psi at 2000 rpm and then drop off to 3 psi at 6500 rpm. A 1750cc engine would make 10 psi at 4000 rpm while dropping off to 3 psi at 13,000 rpm. The boost drop is linear, so that 1750cc engine would make 7-8 psi at redline, and launch at 15 psi using 24 volts. If a blow-off valve is used to bleed off excess pressure, a steady sustainable boost is possible until the capacity of the supercharger is reached. This means that a prepared 1.6-liter four-cylinder can run a sustained 15 psi at 36 volts to 6000 rpm.
Adamal wrote:Hmm... Perhaps a FAQ on the Electric Supercharger with facts as to why it would prove pointless would be in order? This topic seems to show its ugly head every so often...
Why only short bursts?
Think of these batteries as your Nitrous tanks. Like Nitrous, the ESC's instant boost is currently limited in duration, but unlike Nitrous, that restriction will gradually disappear as battery technology improves. Eventually, high-volume capacitors will allow for almost perpetual usage. Until then, a typical battery bank will yield several runs before recharge. And unlike Nitrous, our system will not cost you thousands of dollars in long-term refilling expenses. Most Nitrous users go through at least 1 bottle/week, and at $30 to $45 per bottle, that's a hidden charge of $1,560 a year, every year, forever. Think about it! With our system, you will never deal with costly refills again.
No more refills?
Well, not quite. There is no such thing as free energy. Even our system needs to be recharged, but in this respect, the universal, open-ended design allows for hundreds of ways to do so. It could be as simple as hooking up to a regular battery charger in your garage twice a week, or as futuristic as solar panels. You can upgrade to a high-output alternator like those that power competition audio systems in the future. With a 200-amp alternator, you'll fully recharge quickly while the ESC™ is off. So while you're waiting in the staging lanes or cruising along the strip, you can relax and hurl insults at the Nitrous guys while your system preps for another power burst of awesome boost.
There's more than enough power to remind those high school kids with the neon muffler bearings who their daddy is.
Users browsing this forum: Bing [Bot] and 35 guests
