http://www.users.on.net/~fivebob/documents/2zzge.pdf
http://www.users.on.net/~fivebob/documents/1zzfe.pdf
**EDIT** added link to 1ZZ-FE paper
Mr Revhead wrote:now that deserves a prize as the best find of the year.....
do they have an online library for other engines?
must go look.....
SUBARUCONVERT wrote:i think u will find that they added it to quiet the engine down
Noise suppressing insulation could not be added to the inside of the engine hood, because the hood line was low. Acoustic intensity was measured and a rubber spacer was added between the intake manifold and the block . This filled a volume which was acting as a resonance chamber.
fivebob wrote:SUBARUCONVERT wrote:i think u will find that they added it to quiet the engine down
Yes that's what I though too.Noise suppressing insulation could not be added to the inside of the engine hood, because the hood line was low. Acoustic intensity was measured and a rubber spacer was added between the intake manifold and the block . This filled a volume which was acting as a resonance chamber.
Other features such as a reinforced ladder frame, and an intake manifold spacer was utilized for a sporty engine sound.
Jebus wrote:http://www.autoshop101.com/autoshop15.html
This is another brilliant page.
