Turbo'ing my FXGT on a budget > HELP
Postby Zyros » Mon Jan 23, 2006 1:13 am
Okay, very knew to this scene.
How would i go about turbo'ing my 1990 FXGT Corolla.
I was looking at a GT starlet turbo to put in..
Basically, i know im a noob so dont be to harsh..
What do i need to modify to make it fit??
And how much will it cost all up.
Thanks, hope i aint flammed to bad :(
Zyros
Postby dotdog » Mon Jan 23, 2006 8:27 am
Umm, I wouldnt bother with a GT starlet turbo, they are way to small, your better off going with something slightly bigger, like a td04, thats about all I no tho
dotdog
Postby Mr Revhead » Mon Jan 23, 2006 8:40 am
what do you call "budget"
and how much can you do ya self? honestly....
theres heaps of info around about whats needed. have a search, not just here but the whole web
cheapest option would be to buy one already done.
next prob stock engine with low boost (8-10psi) also depends on what engine u have in it now, tvis or non tvis?
its gunna cost you a few grand. maybe as cheap as 2 or over 5, depending what you can do, and what u need to pay for.
Postby Silent Knight » Mon Jan 23, 2006 8:45 am
Judging from his post I'd say he's going to need to get everything done himself.
So if you are on a budget Zyros I don't think you'll be able to do it. GT Starlet turbo is a small-ish CT9 and if you were concidering teh whole motor that's a NO-NO as you'll more modification to even just get the motor in.
Easiest option if you want boost for you would probably be buying a full running 4A-GZE with loom, ecu etc and just get someone to slap that in for you.
That way you will have boost in teh way of a Supercharger and the fitting of teh motor is not that extremely hard.
Silent Knight
Postby suberimakuri » Mon Jan 23, 2006 9:41 am
you'll need to spend 1k to get a setup suitable for 4lbs, which is the max the stock ecu will fuel for unadjusted.
it will be hard getting a wastegate to operate this low, but not impossible.
it'll make about 15kw at the wheels more than stock.
t25 manifold, turbo, downpipe, oil drains and feed.
suberimakuri
Postby Adydas » Mon Jan 23, 2006 9:44 am
Buy my Turbo.
Adydas
Users browsing this forum: No registered users and 26 guests
