Not inflate the F1s to over 30psi? I have 38psi in the rears and 34psi in the fronts Confused 205/40R17 front and 235/40R17 rear.
Yeah I've had my F1's on for around 10,000km (since September) and they have worn so evenly it looks like they havent worn at all, with those pressures
Leon wrote:They were the control tire for the Production Racing series last year, and the Evo's and WRX's were literally ripping the tire tread to bits in only a couple of races, so I can suggest that if you're doing hard track time, then you should avoid these tires. The same warning would apply for many soft road tires though
neo wrote:They tend to melt, even under the awesome pressure of a 20v at Taupo, I half used a brand new set at a toyspeed track day
flygt4 wrote:i bought a set of 4 b4 xmas. 205/40/17 , retail price was $265 each tho i dont know many people who pay retail for tyres anyway , i got mine a fair bit cheaper
the good stuff above all applies, great street tyre , sticky at low temps , great in the wet etc and awesome lateral grip thru corners.
