Drags on monday
Postby crispy'86 » Sat Feb 04, 2006 12:18 pm
JT wrote:Damn, of all times to have the car out of action. Would've taken that 4th spot for sure. DYO is my specialty :cry:
Unless someone has a car they don't mind being given a workout..... :wink:
Why what's wrong with your car Josh?? Would like to go out and have some fun but that depends when i get the race car done. May end up watching
crispy'86
Postby JT » Sat Feb 04, 2006 1:51 pm
crispy'86 wrote:Why what's wrong with your car Josh?? Would like to go out and have some fun but that depends when i get the race car done. May end up watching
viewtopic.php?t=41682&start=22
Need a new strut, bearing was welded to axle. Got half of it off and Im just about to split hub and disc to see if everything will come out ok. Pete has an ae85 coming in a couple of weeks I might be able to grab a strut out of that.
JT
Postby fangsport » Sat Feb 04, 2006 2:44 pm
Josh, shoot down here and borrow the legs from the rally car..............it ain't going nowhere, especially not without and engine that is trying my patience :(
fangsport
Postby crispy'86 » Sun Feb 05, 2006 3:43 pm
What!! I thought you'de have got that problem sorted out by now.
If you get stuck get hold of Pete , he has the ae85 right now at his place..
Good luck, if you get stuck give me a yell and i'll have a look to see if i can do something to help you out. (clear out and sort out my struts and mark what they came off)
crispy'86
Return to Christchurch / Upper South Island Region
Users browsing this forum: Bing [Bot] and 1 guest
