Plugs questions, ae101
Postby slighty_sykotic » Mon Feb 06, 2006 11:04 pm
Hey,
Under the centre console, underneath the radio headunit etc, just in front of the gearlever there are two plugs in an ae101. They link into the engine loom, and I assume most are for the dash, reserving lights, head lights etc etc. Now, does anyone have the pins out for them... I can't find them.
I can take a pic if people don't understand where I mean, but they are two flat plugs, about 20-30 wires each.
Any help?
--Sykotic
slighty_sykotic
Postby KinLoud » Tue Feb 07, 2006 10:03 pm
Hmmm...
stuff like:
- aircon control coming from the heater/fan/aircon switches to the aircon pump clutch
- fuel pump control
- temp guage sensor
- power to the computer
- idle inputs like lights, aircon, brake
- other stuff that I can't remember
Why do you need pinouts?
Ken
Ham
021 408 863
Postby slighty_sykotic » Tue Feb 07, 2006 10:15 pm
So that I can make those things work :P, got a gze engine loom, totally different.
--Sykotic
slighty_sykotic
Postby KinLoud » Tue Feb 07, 2006 10:36 pm
I think one plug connects to the computer, the other plug connects directly to the engine loom.
What model/year 4agze? AE92bigport, AE92smallport Ae101
What model/year is the lucky car that is getting this motor? AE101 5afe, AE101 4afe, AE101 4age?
Do you have plugs that will fit the 4agze loom and computer
One possible idea is to find a GTZ body loom.
Ken
Ham
021 408 863
Postby matt dunn » Tue Feb 07, 2006 10:50 pm
I know the exact plugs you are on about and there are many variations of them and no wiring diagrams.
There are things like a/c, Diagnosis conector pins, temp and oil gauges, and about five earths,
two or three for the gze only are for the two speed fuel pump setup,
I've been there done that with one of them, 20V to GZE.
Good luck. (haha)
Matt
Postby slighty_sykotic » Tue Feb 07, 2006 11:10 pm
Hmmmmmmmmmmmmmmmmmm,
Ok, guess its going to be a case of tracing back then.. And I don''t even have a 20v loom (complete) to work with :(. I got speed and reverse lights (I remember where they went). Revs and check engine im going to need for sure, fuel pump is not a problem (have run new wires anyway).
The outputs to the headlight relays from the steering colum are in there some where (as headlights don't work). A/c, don't care about them, its gone anyway. Computer power etc doesnt matter, that's all been done from nothing anyway.
I ever told anyone I hate cars?
--Sykotic
slighty_sykotic
Postby slighty_sykotic » Tue Feb 07, 2006 11:13 pm
And horn! my poor poor horn :cry:
The heater fan, window wipers etc are all sweet, same with all the lights (bar the headlights). The inside dome light doesnt work for some reason, power must go through those plugs. Sun roof works.
And another questions, on the back drivers side corner of the engine bay there is a plug with four wires, two are the main power feeds for the dash, one is the output from the key to starter solid relay, and the other one is.....
Anyone know? I havn't found a use for it yet. lol.
--Sykotic
slighty_sykotic
Postby matt dunn » Tue Feb 07, 2006 11:21 pm
slighty_sykotic wrote: two are the main power feeds for the dash, one is the output from the key to starter solid relay, and the other one is.....
--Sykotic
Power to the headlights?
I had problem getting the windows to work from memory.??
Postby slighty_sykotic » Tue Feb 07, 2006 11:27 pm
nah, my windows work fine, so does central locking (that is witrh both of these plugs unpluged.
And holy moly, you might be right! (was checking output from wire and fiddling with stuff, but I didn't try the head lights, ill go check right now.
slighty_sykotic
Postby slighty_sykotic » Tue Feb 07, 2006 11:31 pm
Nah, its not, nothing comes out of it :(
--Sykotic
slighty_sykotic
Postby matt dunn » Tue Feb 07, 2006 11:57 pm
slighty_sykotic wrote:Nah, its not, nothing comes out of it :(
--Sykotic
not a power feed from the battery into the car rather than out of?
Postby slighty_sykotic » Wed Feb 08, 2006 9:01 am
Maybe.... But why would it need another, its already got two big cables... Hmm, I may put some power to it and see if anything starts to work.
--Sykotic
slighty_sykotic
