AE1O1 ENGINE CONVERSION
Postby ON PSI » Thu Feb 09, 2006 11:44 am
HI THERE GUYS IM DOING OA ENGINE CONVERSION FROM A SILVER TOP TO A BLACK TOP, IM HAVING TRUBLE WIRING IT IN TO THE AE101 CHASSI. I HAVE THE BLACK TOP LOOM AND FUSE BOX. ANY INFO WOULD BE VERY HELP FUL
ON PSI
Postby Alex B » Thu Feb 09, 2006 11:55 am
1) Turn your caps lock off.
2) Spelling.
3) What are the accual problems.
Postby slighty_sykotic » Thu Feb 09, 2006 11:57 am
Basically you'r $&#$% :P
As I am in the middle of finding out, there are no diagrams for th ae101 chassis.....
So your on your own :).
Its not hard though, theres 4 wires in a plug at the back drivers side of the engine bay, 2 of those are power, ones the starter solinoid feed, and I dunno what the other one is.
And the rest of the connections from the body to the engine loom happen in two long flat plugs under the centre console.
O yeah, don't forgot the feed by the battery, the big ass white cable is the feed to the heater fan etc, and the little ones are hooked to the headlight relays.
--Sykotic
slighty_sykotic
Postby AceSniper » Thu Feb 09, 2006 7:57 pm
run silvertop loom, get ecu daiagrams for black an silver... solder blacktop loom plugs onto silvertop loom an just use the afm wires for the map sensor
AceSniper
Postby slighty_sykotic » Thu Feb 09, 2006 8:27 pm
I should have said that, yeah, be a hell of alot easier.
Wasnt thinking :)
--Sykotic
slighty_sykotic
Postby Lloyd » Thu Feb 09, 2006 9:01 pm
pyro_sniper2002 wrote:1) Turn your caps lock off.
2) Spelling.
"Actual" ;)
Postby vvega » Thu Feb 09, 2006 9:04 pm
or
just wire the ecu in only
useth afm wires to power up the map aensor and the temp sensore wires
takes about 3-4 hours to do
eazy as
sometimes you have to think ouside teh square lads :D
vvv
v
v
v
vv
v
v
v
vvega
Postby ROBODISCO_20v » Fri Feb 10, 2006 1:00 pm
Have a look on www.club4ag.com they have heaps of useful info on wiring in the reference section
ROBODISCO_20v
