more power out of 20vlave mr2
Postby blue-smoke » Mon Feb 06, 2006 11:54 am
i have had the 20 valve in my aw11 for a few weeks and it goes like a cut cat but wish it had more low down power as well as a bit more overall power, what do you guys surgust , i was thinking some cam gears and cam shalfs as well as a nice exaust
blue-smoke
Postby Chickenman » Mon Feb 06, 2006 12:11 pm
Probably get a new ecu.
There's always going to be a sacrifice, the 4age is a highish revving engine and all the ones that make decent power (that aren't turbo) rev even higher and have even less down low.
Just get a six speed box :D
Baby Jesus
Chickenman
I Am The Walrus!
Postby Wings_Alexander » Mon Feb 06, 2006 2:56 pm
Umm get a dictionary and then sc it!
That will give you more of the low down goodness you require!
Wings_Alexander
Postby Dell'Orto » Mon Feb 06, 2006 3:24 pm
Danny, cams wont benefit both low end and top end, you'll have to sacrifice one slightly for the other.
If you want more overall power, you're better off getting some ZE pistons and turboing it.
Postby ROBODISCO_20v » Thu Feb 09, 2006 10:20 pm
If you get the right duration and lift combo you can give it a broader power band. The previous owner of my Levin told me he had done the cams, when we had them out while doing a rebuild last month we couldn't find any marking/brand name or size on them, but what I can tell you is compaired to a standard black top & silver top it has way more pull from down low & it has even more after installing an Apexi SAFCII as it was running very lean at low revs. It still makes max power at 7600rpm so I didn't loose any top end & gained a lot down low. Just like a VTEC only better, as its not a Honda :lol:
ROBODISCO_20v
Postby blue-smoke » Fri Feb 10, 2006 7:08 pm
yeah thats a good point ........ most vtecs only have one cam shaft ....... f***in hondas , yeah i will look into it aye, at the moment its only a sleeper , outside is stock , inside .... not so stock, i was thinking that ze pistons only have space for the 4 valves ..... would i be cancelling 1 valve out?
blue-smoke
Postby avinesh » Fri Feb 10, 2006 7:14 pm
ROBODISCO_20v wrote:If you get the right duration and lift combo you can give it a broader power band. The previous owner of my Levin told me he had done the cams, when we had them out while doing a rebuild last month we couldn't find any marking/brand name or size on them, but what I can tell you is compaired to a standard black top & silver top it has way more pull from down low & it has even more after installing an Apexi SAFCII as it was running very lean at low revs. It still makes max power at 7600rpm so I didn't loose any top end & gained a lot down low. Just like a VTEC only better, as its not a Honda :lol:
jealous 8)
avinesh
Postby blue-smoke » Fri Feb 10, 2006 7:42 pm
also i was thinking for a new igition coil , leeds and plugs for a small bit of a bite....
blue-smoke
Postby avinesh » Fri Feb 10, 2006 9:50 pm
blue-smoke wrote:also i was thinking for a new igition coil , leeds and plugs for a small bit of a bite....
dont bother changing these if the current ones are good..... coils leads an plugs only make power if the current ones are failing.....
avinesh
Postby ROBODISCO_20v » Sun Feb 12, 2006 7:59 pm
If you're going to change your plugs NGK Iridiums work really well in 20v's The part number for them is BKR6EIX11. I have a set in mine. I also have 7mm Ultra leads & a MSD coil.
ROBODISCO_20v
Postby blue-smoke » Mon Feb 13, 2006 7:50 pm
yeah that sounds like a plan, i might jump up to a link ecu so i can put trumpets on insted of a safc
blue-smoke
Postby ROBODISCO_20v » Sat Feb 18, 2006 3:46 pm
blue-smoke wrote: i was thinking that ze pistons only have space for the 4 valves ..... would i be cancelling 1 valve out?
According to the guys the ZE pistons will work in a 20v
Here are some pick of aftermarket forgies for both. You can clearly see the 5 valves. for more info visit http://www.aclperformance.com.au/Toyota ... istons.htm
http://www.aclperformance.com.au/Toyota4A-GZE.htm
ROBODISCO_20v
Postby Mr Revhead » Sat Feb 18, 2006 8:52 pm
yes ZE pistons work with 20v head.
problem with those ACL pistons is the price 8O and they arnt coated like the stock ones
Postby ROBODISCO_20v » Sun Feb 19, 2006 4:22 pm
The ACL performance pistons for the 4AG are made by http://www.rosspistons.com/ in the states
ROBODISCO_20v
