Post your NA 4AGE Dyno Runs here
Postby ROBODISCO_20v » Fri Feb 10, 2006 1:31 pm
All you out there with Naturally asperated 4AGE's 16 & 20 valve post your dyno runs here to compair. I know they're not acurate comparisons but I'll be interesting to see power & torque curves anyway.
This one was done at a NZPC/Torque Performance dyno day.
This is my AE111 Levin when i first bought it. It had a HKS pod filter, N1 style exhaust & possibly cams but we couldnt' find any markings on them when we had the engine apart to say they weren't standard. As you can see from the fuel it was running very lean at low revs
Will take it for another run once the engine is run in from it's rebuild.
ROBODISCO_20v
Postby suberimakuri » Fri Feb 10, 2006 6:41 pm
www.garagedori.com/tech - look at the top of the page.
suberimakuri
Postby Adamal » Fri Feb 10, 2006 10:07 pm
101KW at the wheels.. Thats not bad! Good job :)
Postby B1NZ » Sat Feb 11, 2006 12:22 pm
dont have a scanner, but mine got 95.5KW@ the wheels on a hub dyno at 7800rpm
Stock except exhaust
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Fortyone.co.nz » Sun Feb 12, 2006 10:42 pm
Cracked the 100 =] The best thing you could do for a few kw's is ditch the HKS filter and slap on an Apexi.
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby 4AGE 8U » Mon Feb 13, 2006 12:20 am
i posted mine up 2 years ago in my bzg and i made 113kw, with exhaust, cams and factory trumpet with no plenum
4AGE 8U
Postby ROBODISCO_20v » Sat Feb 18, 2006 4:01 pm
Fortyone.co.nz wrote:Cracked the 100 =] The best thing you could do for a few kw's is ditch the HKS filter and slap on an Apexi.
1 HP more :!: WooHoo
Better filtration though.
http://www.max-boost.co.uk/max-boost/im ... r_test.htm
http://www.mkiv.com/techarticles/filters_test/1/
ROBODISCO_20v
Postby vvega » Sat Feb 18, 2006 8:10 pm
lol
what a load of shit
vvega
Postby NILPSI » Sat Feb 18, 2006 11:19 pm
I lost my print out in a box when i moved, but i made 101kw @ wheels on a rolling road with intake, exhaust and SAFC
Go the K&N!!!
2017 Triton - The "free supplied by work" daily
2018 Camry V6 - The actual daily
1997 Trueno BZ-G - The Garage Queen
1997 Supra SZ-R - Now with added boost!
NILPSI
Postby GGnz » Sun Feb 19, 2006 1:39 pm
No idea but mine will be higher :lol:
GGnz
Postby GGnz » Sun Feb 19, 2006 1:43 pm
GGnz
Postby vvega » Sun Feb 19, 2006 1:49 pm
perhaps at the motor with no ancellerys and very cold air :D
v
vvega
Postby Truenotch » Sun Feb 19, 2006 3:28 pm
[quote="GGnz"]Isn't stock standard 121.36 kw?
Thats Flywheel kw.
Truenotch
