by AE91Sprinter » Tue Feb 28, 2006 2:25 pm
Ok, replaced the fuel filter - 32$ at BNT, quoted 48 at repco and they didnt even have them in the country... Fantastic! very happy with 32$, nice guys at BNT too.
At any rate, hasnt helped my starting issue.
Once again, for a once over -
checked compression, tested fine.
Tested spark by putting the sparkplug against the block + cranking, spark is there, but perhaps not as nice as id like it - white spark, but a small jump, not over the whole electrode of the plug. Could be the issue, i guess...
Fuel filter replaced, pressure seems a bit better now - needed it anyway, so not wasted money.
Makes a slight knocking sound under load, if the timing is severly retarded it stops it, but at correct timing with any fuel it does it.
Im starting to wonder if i have a small headgasket leak, but that should show up on the compression test...
Perhaps I have a valve issue, but im not overly willing to take the head off it to find its all peachy.
gah. Frustrating.
