the sensor that determines when the radiator fan comes on, what conditions does it need to switch on and off?
Just wondering as im trying to work out what to do with some sensors and stuff and best place to put them etc.
Levin wrote:The radiator fan in my old 20v levin used to just about NEVER come on. And would very rarely read the normal half way on the engine heat dial thingy. And it always sat on cold when I was on the open road in 5th gear. Nothing ever blew up, but it was just real weird.
deaf_rattle wrote:...
fan is currently on all the time
deaf_rattle wrote:true
reason i ask, is because i thin kthe 20v has it on the cold side of the thermostat.
so trying to work out if putting the ae92 fan control sensor on the cold side of the thermostat is the best thing to do.
Ae92typeX wrote:Have you still got aircon?, or if not have you bridged the sensor so the fan is not always on?
Rob wrote:If the sensors are not exactly the same they will give different readings
