Turbo
Turbo
Postby trueno_20v » Fri Feb 24, 2006 10:39 pm
Ive just brought a t3 turbo (off a rb20det) and when its on the angle im mounting it the oil feed and drain isnt straight up and down, when looking at it from the side the feed is at position 10 on a clock and the drain is 4 on a clock lol if you get what i mean its not straight up and down, is this ok or does it have to be perfectly straight?
ADMIN EDIT: signature too large
trueno_20v
Postby Akane » Sat Feb 25, 2006 4:20 am
A rule of thumb is that it has to be within 15 degrees from dead straight (each side).
Postby trueno_20v » Sat Feb 25, 2006 9:07 am
Oh well mine is more like 45 deg, i know i can spin the compressor side of the turbo around but what about the exhaust side of it? Ive taken the braces off and it looks like one peice? :?
trueno_20v
Postby Akane » Sat Feb 25, 2006 10:04 am
I've never seen a turbo that has a 1 piece (core to exhaust housing).
But then I havin't seen much turbos.
You'll have to ask someone else from here onwards.
Postby IH8TEC » Sat Feb 25, 2006 10:16 am
you should be able to move both, my t3 (not off skyline) has a bolted exhaust housing, and like retaining plates on the compressor, i can rotate the exhaust by taking out all the bolts 6 and move it round to the next hole that lines up. put bolts back in
hope it helps, if they are similar
Postby trueno_20v » Sat Feb 25, 2006 4:20 pm
IH8TEC wrote:you should be able to move both, my t3 (not off skyline) has a bolted exhaust housing, and like retaining plates on the compressor, i can rotate the exhaust by taking out all the bolts 6 and move it round to the next hole that lines up. put bolts back in
Yea mine has those 6 bolts with the plates too, i took them off and i think its rusted up and looks almost like its 1 peice.. i guess it wouldnt have bolts there holing nothing would they.... lol
trueno_20v
Postby IH8TEC » Sat Feb 25, 2006 4:23 pm
it should come off, tape it lightly with a soft face hammer, just make sure you dont damage the turbine wheel in the process,
goodluck
brendon
Postby Bazda » Sat Feb 25, 2006 6:37 pm
yea you definatly beable to unbolt the exhaust housing, they do seize up but a gentle tap here and there should fix it
Postby trueno_20v » Sat Feb 25, 2006 9:37 pm
Ive been tapping it and its not gonna move..what else can i try? Il get a pic tomorrow aswell
trueno_20v
Postby Dell'Orto » Sat Feb 25, 2006 9:44 pm
Give it a blast with 556, and let it sit overnight and see what happens.
Postby strx7 » Sat Feb 25, 2006 10:49 pm
add some form of penetrive solution and let it sit, then use a heat gun to warm the exhuast housing causing it to slight expand, and it should come off.
Postby trueno_20v » Sun Feb 26, 2006 10:15 pm
well today i sprayed some 556 on there and heated it with the heat gun and tapped it off with the hammer, came off pretty easy..Got the housing off and saw that the exhaust wheel was buckled badly then it fell off!!!!!!Also noticed 5-6 cracks though the exhaust housing..so ended up taking the shaft out and it looks like it has been over heated..the shaft is gold and turns black as it gets closer to where the wheel onces was lol so now ive wasted $180 and am now looking for a new turbo (td05, td05h, tdo4??)
trueno_20v
Postby trueno_20v » Mon Feb 27, 2006 9:40 pm
Ive found a TD05H 14B that ive basically brought, are they much smaller than the T3 off rb20det??
trueno_20v
Postby Steve123 » Tue Feb 28, 2006 7:53 pm
similar size really.
Steve123
Postby evil_si » Tue Feb 28, 2006 8:27 pm
haha the nissan t3's are bad for that, ive destroyed a few by getting the exhaust housing off. not much you could have done really, stupid ceramic turbine.
does the exhaust housing have 04U cast on it anywere? if so i could be interested in buying it off ya..
evil_si
Postby sk1dlet » Tue Feb 28, 2006 8:40 pm
whats so special about the O4U housing?
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby trueno_20v » Wed Mar 01, 2006 8:31 am
evil_si wrote:haha the nissan t3's are bad for that, ive destroyed a few by getting the exhaust housing off. not much you could have done really, stupid ceramic turbine.
Ill have a look after work for ya :wink:
trueno_20v
Postby dash » Wed Mar 01, 2006 10:50 am
rb20 turbo has a "t3 footprint" but flows closer to t25/28
td05 14b can hit 300hp with the boost wound up, and is alot tougher than the fickle rb garbage
Folks in the u.s. enjoy the challenge of taking their 3000 pound 2L mitsubishi awd street cars down the dragstrip in the 12sec zone. Many have done so with minimal mods - not bad for a 12-15 year old $100 oe turbo!
dash
Postby trueno_20v » Thu Mar 02, 2006 9:30 pm
yup its got 04U on it, you have a pm :wink:
trueno_20v
Postby trueno_20v » Sun Mar 05, 2006 6:24 pm
anyone know if the VJ20 off a familia gtx are any good for my 20v? ive got a mate with one i could get but i think it could be a bit small?
trueno_20v
