4340 is a grade of steel. high strenght and quality. and explaines why no one wants to do it.
the dvd would be a good watch, wouldnt mind seeing it
if you could watch it and see anything worth intresting, it would be aprreciated Fraud. thanks
All_Fours wrote:I can't blame nooone for wanting to machine a crank for you from a steel billet - it's a stupid idea! Even a cast steel crank will have better grain structure than one machined from a billet. Not only that but there's no way you'd be able to machine a billet down to the shape of a crank without it distorting. There would need to be a lot of post-machining heat treatment and reshaping of the crank to make it sound, and even then I wouldn't like the chances of it surviving high revs for long.
Also do you even know what 4340 means?
