transplant help
transplant help
Postby bluemaumau » Thu Mar 02, 2006 10:43 pm
subject car: ae101 corolla wagon (4afe)
donor cars: ae92 afm trueno gtz (4agze)
: ae101 levin (no engine)
im putting the 4agze in the wagon and i wanna give the wagon 4 wheel disks.
so questions
1. which engine mounts do i use ? gtzs, wagons, custom, other
2. which hubs do i use ? i have a lsd gbox on the gtz so i can only use the gtz hubs, correct? if so, do they fit?
3. ther will be more questions soon. lol :D
Postby bluemaumau » Sat Mar 04, 2006 5:18 pm
shot every1
:roll:
Postby deaf_rattle » Sat Mar 04, 2006 5:44 pm
use your mounts off the original motor
they should bolt up to the new motor
Postby deaf_rattle » Sat Mar 04, 2006 5:45 pm
as for brakes
join up to the toymods forums. there is plenty of talk on there about the brake upgrade you are wanting to do
Postby bluemaumau » Sat Mar 04, 2006 5:46 pm
thank you deaf rattle :D
Postby strx7 » Sat Mar 04, 2006 6:33 pm
GTZ hubs have the same spline as the 4AFE/4AGE powered cars.
if you want BIG axles you can press the drive flange piece from a V6 Camry into the corolla HUB carrier and then alter the length of V6 Camry axles to suit, that will give you an bullet proof drive train.
Postby bluemaumau » Sat Mar 04, 2006 7:08 pm
shot bro. good info.
