Amature planning a 3sgte swap
Postby mr2--mad » Tue Feb 21, 2006 2:14 pm
well Question 1. can i see where the engine no is stamped on a sw20 while the engine is still in the car? where is it?
well Question 2. i have a good head( 1111188383)off a celica i think? will this bolt straight onto a MR2 3SGTE short block (9101816MR2)
well Question 3 , if that works will this combo fit straight in and run an (1992 sw20 0068265,sw20AJMZZ this is the car im tryn to find the position of the block number)
:twisted: i wanna go sideways again? 8O
mr2--mad
Postby Silent Knight » Tue Feb 21, 2006 2:22 pm
If you pop the engine cover and lift it there should be a tag on the inside with the Engine code etc printed on it.
Silent Knight
block number
Postby mr2--mad » Tue Feb 21, 2006 2:27 pm
my bad . where is the BLOCK number :oops:
mr2--mad
Postby Punter » Tue Feb 21, 2006 2:32 pm
Why do you need to know the block number anyway?
Punter
Re: block number
Postby Silent Knight » Tue Feb 21, 2006 2:36 pm
mr2--mad wrote:my bad . where is the BLOCK number :oops:
I'm no expert here but it should be stamped on the block.
Where exactly on the block however I don't know. Ask one of the better knowing 3S boiz on here...
Silent Knight
Postby mr2--mad » Tue Feb 21, 2006 2:56 pm
yip your no expert but neither am i.what side of the engine would do ?My engine is stuffed, it is in the car still .There is an engine for sale with the block number9101816. if i can find my block number , i can Then find out if they are the same blockjust trying not to make mistakes lol. i wanna buy this short block :D but i want to know its same Gen as mine before i drive 18 hours to pick it up
mr2--mad
Postby markbrown06 » Sun Mar 05, 2006 5:42 pm
any 3s block shoud fit, i have a 1997 caldina block on my 89gt4. there are 2 different blocks i know of which is where i had problems the fwd and 4wd block, the 4wd hav more clerance for the gearbox. the mr2 might be slightly different again but i doubt it.
4wd dohnuts in da GT-FOUR our
markbrown06
