how wide can you go, ae92 fxgt
Postby deaf_rattle » Sat Mar 11, 2006 10:23 pm
how wide can you go before tyre width becomes an issue.
ae92 fxgt
Postby Caveman » Sun Mar 12, 2006 12:04 am
Im running 195 and the rear is 2mm off the strut and pretty much inline with the gaurd. I think its on 6 inch rims with 35 offset, not sure though...
205 would probably be a maximum.
Caveman
Postby Jazza » Sun Mar 12, 2006 8:05 am
6 foot rims? :P
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby Ae92typeX » Sun Mar 12, 2006 11:23 am
lol@ 6 foot rims.
I ran 205's on my ae92 a few years back. Rear clearance was fine, just minor fron guard rubbing which was easy to sort. I cant reacll the offset however sorry.
Ae92typeX
Postby THA SHZ » Sun Mar 12, 2006 11:52 am
offset is 35 , and the width depends on ur rollin diameter , i have fit 215/35-18 on an ae92 before with no probs but remeber its all to do with ur rolling daimeter by not exceeding wot factory intended 8)
THA SHZ
Postby Ae92typeX » Sun Mar 12, 2006 11:56 am
yeah...I probably should ahve stated I had it lowered also- otherwise it would have been no issue
Ae92typeX
Postby Caveman » Sun Mar 12, 2006 12:08 pm
Jazza wrote:6 foot rims? :P
:oops: eidt
THA SHZ dont you have flares (bash out guards :lol: ) That would allow you to go wider?
My car is lowered too, around 45mm, rubbing on the front with hardish cornering, easy to fix though.
Rear is 5mm off the strut, about 20mm away from the outter lip of the guard on 195/60/14 35 offset
Front is fine.
Could probably go 205/215 at maximum as THA SHZ said.
Caveman
Postby THA SHZ » Sun Mar 12, 2006 12:13 pm
haha yeah i have a great kit for flaring the rear guards like mine , it involves a cresent and a bottle of beer hahaha :lol:
THA SHZ
Postby soopachargen » Sun Mar 12, 2006 2:14 pm
i have 205/40/17s on a 17x7... with shagged shocks it used to rub in the back under hard cornering but now with the new ones its fine.... it sits with the top of the rear rims in the guards with people in the back and still doesnt scrub my cars an fx-g 4 door tho so i dunno if i have the same inner gaurds at the back... my plastic inner gaurds at the front have been removed and there is a polished piece on the end of my gze gearbox from full lock...
When in doubt, down and out.
soopachargen
Postby Fred » Wed Mar 15, 2006 5:48 pm
205/40/17 and as low as can go and sweet on rear front had a lil rubing at full lock but put it a lil higher and cause of that no more rub
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
