6 speed gear box strength vs 5 speed
Postby tomo1985 » Sun Mar 12, 2006 5:08 pm
I heard that the 6 speed is alot weaker then the famous 5 speeds strength. Is this true? I have never seen a fwd 5 speed break in a corolla is this about to change?
tomo1985
Postby rallymazda » Sun Mar 12, 2006 5:34 pm
my 5speed is breaking!!!!!
but i think the difference isnt really that great,still a good box
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby rolla_fxgt » Sun Mar 12, 2006 7:13 pm
All boxes break, but yes the 5spd is stronger than the 6.
My 5spd in my levin needs a new 2nd gear syncro when i can be bothered getting round to it, believe its a kinda common toyota gearbox fault
rolla_fxgt
Postby sergei » Sun Mar 12, 2006 7:54 pm
I had 5 speed C52 a have 6 speed C160 in my AE101, 6 speed defenetly has weaker synchros, but saying that 5 speed is not better. If you want a strong gearbox use E5X off GTZ, becuase internally 6 speed and 5 speed are very similar, I destroyed my 5 speed by "loading" it up in the corner, the spyder gears shat themselfes, at least I will not have that problem with 6 speed due to torsen lsd does not have spyder gears... but with my current 6 speed 2nd and 5th syncro is on the way.
To compare those to E154 wich is in my celica, well E series gearboxes are way stronger, and with my E154 the syncros are just amasing, does not have that "don't want to go in the gear" feel.
Postby Mr Revhead » Sun Mar 12, 2006 9:23 pm
so u broke the diff, not the gears :P
no real strength difference in them, i know of ppl using 6 speeds in 4agte aw11s with no problems. but u have to consider driving style etc
Postby Cahuna » Sun Mar 12, 2006 9:52 pm
IMO opinion the 6 speed (C60) diff is definitely weaker than the 5 speeds (C52, C56 etc) - just ask Bad20v! My 6 speed is yet another with a blown diff...
When I broke my 5 speed (a loos bolt decided to wander through 5th gear :? ) I took both my 5 speed and 6 speed to my mechanic to see what could be done with them, he pulled both apart and spent some time poking around to see what fitted where. He found that the gears for the 6 speed are slightly narrower than on the 5 speed, necessary to cram the extra gear into the same space. Probably not enough to affect the strength of the gearset too much. More significantly the 6 speed pinion driving the diff is 5-6mm thinner than that in the 5 speed (again so that everything will fit in), making the diff weaker - all the broken 6 speeds I've heard of are due to the pinion stripping itself.
We know that four-wheel drive doesn't work in a racing car, and I proved to myself that it doesn't work very well for rallycross. I'm absolutely convinced that it has no future in rallying, either, even if the regulations allowed it. - Roger Clark (rallying legend), circa 1976
Cahuna
Postby bad20v » Wed Mar 15, 2006 1:05 pm
:cry: :cry: :cry: shut up! :cry: :cry: :cry:
Two broken 6 speed gearboxes and counting.... :lol:
Thank-You.
bad20v
Postby barryogen » Wed Mar 15, 2006 4:28 pm
inherently, if made with the same material, and made to fit in the same space, a 6spd box will be weaker than a 5spd box... however if you don't drive it like a fscktard, both should see out the vehicle. following this back about 25 years, you'll find that the first 5spd boxes were weaker than the 4spd boxes(of the time), and so on and so on.
if the boxes have different materials in the steel/what-ever-they're-made-of, then then you'ld have to investigate it further, probably with the help of some very expensive testing.
barryogen
2ZZ Guru in training
Postby vvega » Wed Mar 15, 2006 6:29 pm
Cahuna wrote:IMO opinion the 6 speed (C60) diff is definitely weaker than the 5 speeds (C52, C56 etc) - just ask Bad20v! My 6 speed is yet another with a blown diff...
interesting
the diff is the same as the 5 speed
so is it the diff thats dieing or the output shaft final drive
thinner does not mean weaker
v
vvega
Postby Cahuna » Thu Mar 16, 2006 9:10 am
Not 100% sure but I think on my gearbox the mechanic told me it was the final drive out of the gearbox that had stripped, and that this was the part that was thinner on the 6 speed. Looked to me like the part that drives the crownwheel - the crownwheel was also stuffed.
(To be honest when I look at a gearbox innards it just looks like a whole pile of cogs, bearings and funny unidentifiable bits - the best I can do is identify the parts that got munched! :lol: )
Cahuna
Regarding 6spd weaker ova 5sp
Postby RXI_Rola » Thu Mar 16, 2006 4:24 pm
It's interesting what very one has to say about there comparisons between the 5 speed and 6 speed.
I have now had my 6spd for almost 6 years. Got it with 67000kms and only started giving me hassles at 167000 only one bearing collapsed. I race every chance I get been on puke a few times also ran meremere a few times the cars now @ 190000kms. Still going strong done burn outs and that to. Also my box has no LSD only open diff. The box’s is still holding up.
But in turbo’d or any charged application I would second the choice of getting a GTZ box.
1 tough 20 Valve
RXI_Rola
Postby vvega » Thu Mar 16, 2006 6:15 pm
a lsd will put more loading on a final drive than a open diff
v
vvega
