TRD Man wrote:Chickenman wrote: That is where the only valid comparison can be made as a bzr should go around a circuit more quickly.
Care to qualify that?
I dunno, that's why I was asking.
Does a higher rear weight bias make a difference? Does lighter weight and therefore later braking make a difference? The power to weight ratios are pretty close (assuming the runx has all the power that is claimed.. claims come from the same place for the b/t and the 2zz)
You would assume the later and therefore more developed car would outperform the older model but I think they would be pretty even.
I don't really know, just good to discuss these sort of things I guess. Someone always comes out with something definitive eventually.
The celica on the other hand... Mmmmmmm
The pictured car managed a 15.3 in stock form (with the flappy bit that controls the intake below 3000rpm removed) and that's pretty good for a fwd.
I do think the 5 speed box would be better in all of these cars though, what you guys think?
