**AE101 GTZ Knock Sensor Help**
Postby XS1V » Mon Mar 13, 2006 11:02 am
I have my 4agze running now after the rebuild, and as it has a smallport 4age block the knock sensor hole is under the s/c. This means i cant put the sensor anywhere and was wondering how do i trick the ecu in to thinking everything is fine??
I have extended the wires from the sensor into the center console so i have both power and earth if one is needed 8)
Anybody know how to do this??
Brad
ST205 Group A Rallye #2363
XS1V
Postby XS1V » Tue Mar 14, 2006 11:14 am
Bump
XS1V
Postby gepsk8 » Wed Mar 15, 2006 9:29 pm
i think u will have to tap the hole out. gud luck. no u dont wana ran any boosted car with out a knock sensor!! it retards the timing to stop pinging asks cambo1 he knows all about it when ur knock sensor $&#$% out.
gepsk8
Postby XS1V » Wed Mar 15, 2006 9:33 pm
Yea i realise that :) but i dont really want to be drilling into my block and its gonna be kind of hard doing it in the car :?
XS1V
Postby XS1V » Sat Mar 18, 2006 10:22 am
Bump
XS1V
Postby sergei » Sat Mar 18, 2006 10:28 am
just bolt it on somewhere else on the block, there are 2 support beams supporting inlet manifold from behind, I think the thread on the holes is the same, just bolt it on there...
Postby Mr Revhead » Sat Mar 18, 2006 1:08 pm
i have same a similar issue...
im gunna try sergeis idea first..
other one i had was to find 2 holes and bolt a steel plate between them
i was gunna weld a boss on that for the sensor, and as close as i could to that i was gunna drill and tap a hole either side so i could screw some bolts in and wind the tension up so its as close to a solid piece as i could get it.
Postby dickhead » Tue Mar 21, 2006 8:35 pm
Could one of you guys post a pic of the plug that connects to the ae101 gze knock sensor? i bought one recently off toyspeed but the only plug it connects to is the one wire green one.... and i thought that was the plug to the fan switch???
dickhead
