Amp Question
Amp Question
Postby nmemr2 » Fri Mar 17, 2006 2:04 am
have 2 subs and am wanting to connect both to one amp.
problem being that amp in question is the Rockford T10001BD mono.
possible?
SW20, a work in progress for 2 years now, all i need to do now is work on it
nmemr2
Postby jc25t » Fri Mar 17, 2006 7:14 am
What subs have you got?
jc25t
Postby nmemr2 » Sat Mar 18, 2006 1:58 am
intrigued as to how that makes a difference but ok
lanzar 500wrms 12 inch times two
nmemr2
Postby Alex B » Sat Mar 18, 2006 2:00 am
It makes a diffrence because diffrent subs have diffrent ohm coils. Yes that will work fine. Bit of a wast of a good amp with those subs tho.
Postby nmemr2 » Sun Mar 19, 2006 4:15 am
how would i wire it up though?
the amp i had died so need a new one. entire system is getting an overhaul to match the new amp but for now its just a new amp. then new subs and another amp to go with them and the rest to follow
nmemr2
Postby Caveman » Sun Mar 19, 2006 2:36 pm
1. Swap lanzar for RE/DD. 1 DVC DD will kill two lanzars hands down, something like a 3510.
2. If your gonna use the two lanzars wire them in parallel to the amp 8) The amp should be good for 1 ohm so no problems.
Caveman
Postby Alex B » Sun Mar 19, 2006 7:42 pm
Dude, not every one is into SPL, there are plenty of other good subs out there :roll:
Postby eritate » Sun Mar 19, 2006 7:48 pm
yer
If your wanting to be cheap :)
Get a pioneer tsw305c or along that lines those are good subs
You can get some cheap rockford fosgate punch subs that go hard or even a sony xlpod sub from repco
eritate
Postby Caveman » Sun Mar 19, 2006 10:58 pm
pyro_sniper2002 wrote:Dude, not every one is into SPL, there are plenty of other good subs out there :roll:
Not suggesting he get into SPL, a DVC will sound omg loads better than SVC, better cone control, response, etc not to mention it'll take up less room.
DD's are cheap anyway, i sold my dd2010a in an ABC box for $150. My mate can get brand new RE for $200.
Caveman
Postby Lloyd » Mon Mar 20, 2006 12:11 am
DVC wont make an ounce of difference to how it sounds compared to the SVC version of the same woofer. All it will do will give dfferent loading options
Postby nmemr2 » Mon Mar 20, 2006 1:55 am
cheers guys
looking at the rockford T212D4 subs to go in or the equivalent DD sub if price is right.
thing is you have to remember as well is that all this is going into an MR2
nmemr2
Postby Caveman » Mon Mar 20, 2006 10:05 am
HRT wrote:DVC wont make an ounce of difference to how it sounds compared to the SVC version of the same woofer. All it will do will give dfferent loading options
I would have to disagree considering i've run dd2010's, dd3510's and dd2510's. The 3510 had a much more defind note, especially at the lower frequencys. You could definatly tell the DVC was better.
All 3 of those subs have very similar qts, qms, qes, fs, etc, etc
Anyway in your space precious mr2 you'll probably only want 1 sub anyway, unless your going to asthetics or spl.
I strongly recommend dd, but have heard good things about re too.
Caveman
Re: Amp Question
Postby Chickenman » Mon Mar 20, 2006 10:18 am
nmemr2 wrote:have 2 subs and am wanting to connect both to one amp.
possible?
You could just run them in series, amp doesn't have to work very hard and you'll have a harder time killing them.
What other amps/speakers are you using?
If you've seen a woofers excursion at high volume you'll know what kind of things you're timpanic membrane is gonna have to put up with when the sub is right beside/behind you! Not to mention the pounding your kidneys and liver will take.
I personally think you're over endowing the car with that amp, unless you're very judicous, the potential for damage is very high.
Baby Jesus
Chickenman
I Am The Walrus!
Postby nmemr2 » Mon Mar 20, 2006 11:29 am
the plan is for SPL and aesthestics.
i know its a small car and its more than most have in larger cars but i like my car and like sounds so im making it work.
other speakers are a pair of sony 6X9 and pair of Sony 6.5 coaxials
all to be replaced soon
nmemr2
Postby Caveman » Mon Mar 20, 2006 7:17 pm
If your going spl your gonna need a WAY bigger amp. Did you meet scooby at aut? hes got an awsome setup with 2 9510's and 2 strapped 1000d's/3000d's (cant remember) netting 140db 8) Really good bang for buck and thats in his wagon too
Caveman
Postby nmemr2 » Tue Mar 21, 2006 12:21 am
well more amps to come, probably 4 T1001BD amps in the final setup for just the subs as well as others to run thje rest of the speakers. its just going to come together slowly. i m still looking at DD stuff but dont like the look as much but still a possibiluity
nmemr2
Postby samlloyd » Tue Mar 21, 2006 8:15 am
DD dont make pretty subs.
If your after pretty, go sony or the like.
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby toyonut » Tue Mar 21, 2006 6:49 pm
where are you going to put all the amps?
I would look at 2, 4 ohm dvc subs(whatever brand/size takes your fancy but preferably not new lanzar!) and class d mono block to power them. (if your amp is 1 ohm stable go with that.) I wouldnt go with dd in an mr2 as they require huge ported enclosures (3 cu.ft ported is not uncommon)
then get one really good set of front components (2 way tweeter and woofer or 3 way woofer, mid and tweeter) of any brand (preferably mid to high level eg $400+) and bridge a 4 channel amp into them. Or get a 2 channel amp with 200 watts per channel or so.
A setup like this should get you high 130-low 140 db scores and, if you turn the subs down, good sq as well.
Brands are up to you go with what you like.
Just my opinion though, its your car.
toyonut
Postby tomo1985 » Wed Mar 22, 2006 11:29 am
If you want something that looks the business and will go well go RE they make great looking subs that also hold world records beside DD. Id go for one 3000D E-Audio amp maybe two this thing will put out over 3kw and can be loaded down to .5ohm. Then go for two SX or higher spec model if your budget will let you 10 or 12inch subs. You can have the coils changed to suit your needs if you were to buy two amps.
Costs abouts
3000D = $2500.00 or two for abouyt $4500.00
RE SX = $800.00
Yellow top optima = $400
0 gauge cable = $300
I would also suggest in buying some aero ports for your box as i gained over 3db using these in my setup.
Dynamat Extream (sound deading) = $600
Note. all these prices are rough estimates.
Hope this helps.
And when you have spent all this money making you car loud you must get a good alarm, try and make everything stealth and this is the best defence.
tomo1985
Postby Mr.Phreak » Wed Mar 22, 2006 11:39 am
How the hell did a "How do I wire up my two subs to my amp" thread turn into a "Buy this instead" thread?? :roll:
Mr.Phreak
