by KinLoud » Wed Mar 22, 2006 8:39 pm
Dumb question...
1.
Could you get a 4age block, cut a 5cm to 10cm slice off the top, drill out out the head bolt holes and use that as your torque plate?
Or
2.
Get a head, remove all moving parts and inserts, bore out the combustion chamber area to a bit bigger than the bore required and use the head as your torque plate?
Problems with 1. - the bore would be exactly the same as the bore you want to bore out... is this a problem?
Problems with 2. - once you bored 4 big holes would it be rigid enough?
Ken
Hamilton
021 408 863
