Does anyone have a Torque Plate for a 4age?
Postby 4agtepwr » Tue Mar 21, 2006 11:39 pm
Just wondering if anyone has one that I can hire off them to save me making one :)
Willie
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby Jebus » Tue Mar 21, 2006 11:42 pm
WTF is a torque plate? :?
Jebus
Postby bluemaumau » Tue Mar 21, 2006 11:42 pm
Jebus wrote:WTF is a torque plate? :?
what he said :?
Postby 4agtepwr » Tue Mar 21, 2006 11:54 pm
It bolts to the head surface of the block and when talked up pretty much puts the block under the same tension as when the head is bolted on.
So this means that when you bore and hone a block with the plate on you can ensure that the bores will stay perfectly round when the head is bolted back on, when you take the plate off the bores can go slightly out of round.
I dont really think you need to do it, if its a fairly stock engine but im just trying to build the best engine i can afford to.
4agtepwr
Postby Dragger_Dan » Wed Mar 22, 2006 12:53 am
Hmmm, never heard of this device before.
But wait..... google has found it
http://www.yother.com/perf.htm
Still don't actually know its purpose tho.
Dragger_Dan
Postby RedMist » Wed Mar 22, 2006 7:31 am
A head will stretch and contort a block.
You want all your bores to be straight and round when the head is installed.
You can't bore through a head.
As such a torque plate is installed to stress the block to simulate the installed head. Then you bore with the torque plate in place.
Its a minor effect, however very important when attempting to get everything from an engine.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby NA Drifter » Wed Mar 22, 2006 11:13 am
is that possible to bore the engine upside down?... using a "spare head" bolted onto it? so you will get the same effect?? :P
Keith
NA Drifter
Postby Dragger_Dan » Wed Mar 22, 2006 11:39 am
NA Drifter wrote:is that possible to bore the engine upside down?... using a "spare head" bolted onto it? so you will get the same effect?? :P
Hmmmm, that's a damn interesting question.
Dragger_Dan
Postby wde_bdy » Wed Mar 22, 2006 1:25 pm
I don't think head on would work, would end up leaving a lip at the top of the bore.
Callum
wde_bdy
Postby 4agtepwr » Wed Mar 22, 2006 1:26 pm
Well it would be possible to bore the block not ideal though and you wouldn't be able to hone it using that sort of setup as the stones need to come out the bottom and top of the bore a little. Looks like I may have to make one.
4agtepwr
Postby 4agtepwr » Wed Mar 22, 2006 5:42 pm
Nobody? :(
4agtepwr
bugger
Postby ezy10s » Wed Mar 22, 2006 5:57 pm
Dont look like it dude- If you gona get one made ill go halves w3ith you though as ill be wanting to use one in the near future
Member #244
Gone fishing until further notice
ezy10s
Postby KinLoud » Wed Mar 22, 2006 8:39 pm
Dumb question...
1.
Could you get a 4age block, cut a 5cm to 10cm slice off the top, drill out out the head bolt holes and use that as your torque plate?
Or
2.
Get a head, remove all moving parts and inserts, bore out the combustion chamber area to a bit bigger than the bore required and use the head as your torque plate?
Problems with 1. - the bore would be exactly the same as the bore you want to bore out... is this a problem?
Problems with 2. - once you bored 4 big holes would it be rigid enough?
Ken
Hamilton
021 408 863
Postby wde_bdy » Wed Mar 22, 2006 9:46 pm
Solution 1, simply over bore the torque plate you've made. Question is, would it be less work than making a torque plate out of a chunk of steel? Not much less I would think, and probably less effective.
Calum
wde_bdy
Postby 4agtepwr » Wed Mar 22, 2006 9:58 pm
Its not all that much work its just one more thing I have to make, Just have to find a piece of steel 50 odd mm thick and other ppl will be able to borrow it after im finnished with it :)
4agtepwr
Postby 4agtepwr » Thu Mar 23, 2006 6:18 pm
Well im getting my piece of 50mm plate 8) profile cut at the mo so ill post some pics up when ive finished making it and when the blocks sitting on the boring bar.
4agtepwr
