Nope, RE are about as anti-bling as you can get, they're purely about performance. That new XXX has about twice the excursion (read - in and out movement) of any other commercial sub on the planet. It can do over 110mm of total linear controlled throw, and even more if you want SPL. To put that in context, most cheap subs have about 10mm total throw, and most good subs somewhere between 20 and 30mm total throwbarryogen wrote:purely for bling?
The new one is the big oneMINTFX wrote:So the newer ones are stubbier then the older ones? Those looks crazy.
Blackrazor wrote:It can do over 110mm of total linear controlled throw
Blackrazor wrote:The new one is the big oneMINTFX wrote:So the newer ones are stubbier then the older ones? Those looks crazy.
LOL no.NVD05X wrote:i've never seen that brand before... must be an NZ thing?!
pyro_sniper2002 wrote:Around the $1500 mark IIRC (but dont quote me) and a beast of an amp to power the thing.
