Gearbox ID - how?
Gearbox ID - how?
Postby Vertigo » Mon Apr 03, 2006 2:12 pm
i cant figure out what gbox my ae80 has. its a 1984 and came with a 2A carb engine.
anyone have a website listing the different toyota gboxes?
TVIS just kicked in, yo!
Vertigo
Postby Silent Knight » Mon Apr 03, 2006 2:24 pm
It should say on the Vin plate on the firewall what kind of gearbox it is.
Otherwise gearboxes normally have a build plate on the side of them that says what type they are.
Silent Knight
Postby Vertigo » Mon Apr 03, 2006 2:33 pm
unfortunately mine does not id it on the VIN plate. :(
guess ill have to poke my head into the engine bay..
Vertigo
Postby Vertigo » Mon Apr 03, 2006 3:42 pm
cant see any obvious markings...
anyone know of a website with this info?
ooh, btw its a FWD
Vertigo
Postby Silent Knight » Mon Apr 03, 2006 3:45 pm
Silent Knight
Postby Punter » Mon Apr 03, 2006 3:51 pm
If its a jap import it will have the box code on the firewall, but since its a '84 I would say its NZ new, which gives you a string of numbers and letters meaningless to us mortals.
AE 80's are FWD right, if so I would say you have a c50
Punter
Postby Vertigo » Mon Apr 03, 2006 3:59 pm
ok, thats a good start.
must be one of these, and c50 is looking likely... but still not sure.
Vertigo
Postby Punter » Mon Apr 03, 2006 5:27 pm
Does it have a bulge for the starter only on one side or both??
Punter
Postby Vertigo » Mon Apr 03, 2006 5:45 pm
i think on only one side.. will check
yep, definately only on one side (front side)
Vertigo
Postby Punter » Mon Apr 03, 2006 6:51 pm
Then its a c50, IIRC the c52/c56's have a bulge on both sides.
Punter
Postby pc » Tue Apr 04, 2006 12:06 pm
This has been much confusion for me also. I can get the gear ratios for lots of gearboxes, but can't get anything that matches up the gearbox type, i.e C52 to the number stamped on the gearbox i.e 6325865. So without an adequate build plate there is no way of reading what the gearbox is. NZ new cars seem to have the gearbox type 'thames' F@#$!!!
Has anyone got documentation on how this system works?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Distrb » Tue Apr 04, 2006 1:28 pm
Punter wrote:IIRC the c52/c56's have a bulge on both sides.
Some do... some dont. Have yet to find what causes there to be one on both sides....
Distrb
Regular Poster
Postby Punter » Tue Apr 04, 2006 3:08 pm
Distrb wrote:Some do... some dont. Have yet to find what causes there to be one on both sides....
hmmmmm... well that sucks.
Anyone know how to tell them apart then?
Punter
Postby Vertigo » Tue Apr 04, 2006 4:35 pm
if punter is correct, i would say an older car, like an 84, would have a c50. from that you could probably work out what gearbox a particular model would be most likely to have, but this method is by no means accurate.
Vertigo
Postby pc » Tue Apr 04, 2006 6:02 pm
I think Punter is incorrect also. I have a gearbox which the build plate said was a C52, and it only has one starter motor 'bulge' on the front.
AFAIK if you don't have an accurate build plate to match the gearbox, your stuffed.
red car
Manfield - 1:24s
pc
Postby Punter » Wed Apr 05, 2006 9:54 am
pc wrote:I think Punter is incorrect also.
I was just going by what I have seen of c series boxes, which is obviously not much :oops:
Punter
Postby Quint » Wed Apr 05, 2006 2:00 pm
take the gearbox out and count the output shafts revolutions campared to the input shafts revs
match it up, and u'll be away, bugger of a way to do it, but if you need to know. *shrug*
Quint
Postby pc » Wed Apr 05, 2006 4:18 pm
Yep... if you know the final drive/ratios etc. that is the only accurate way that I know of.
red car
Manfield - 1:24s
pc
