Blitz Power Meter i-D III
Postby Silent Knight » Mon Apr 03, 2006 3:17 pm
MODS if this is in the wrong section feel free to move. I thought this would go down as technical hence me posting it here...
Has any one had any sort of experience with these previously?
I am thinking about acquiring one at some stage but I would like to know from people who have used them before exactly how accurate these units are?
Would it be a good choice getting one of these or can anyone recommend any other units that does similar things in the same sort of price range as the Blitz unit?
At the moment I can get one of these for around 253$USD from just a quick look around.
Silent Knight
Postby Dell'Orto » Mon Apr 03, 2006 4:47 pm
Rob had one in his WRX, which according to that made 1001hp :lol: Though I think his was the earlier model, so the later ones may be more accurate.
Postby MrOizo » Mon Apr 03, 2006 5:49 pm
I had one in the Supra for a while.
its all good in theory but dioesnt account for G-forces like the Apexi RSM does. well the one i did didnt anyways - not sure about the III
If you're looking at something for metering power, go for the RSM, and get the G-Sensor ;)
MrOizo
Toyspeed Legend
Postby Silent Knight » Mon Apr 03, 2006 5:50 pm
Does the RSM give an estimated HP figure aswell?
Silent Knight
Postby MrOizo » Mon Apr 03, 2006 5:55 pm
i'm sure it does. prob not hahaha
it accounts for G-Forces tho.
the blitz meter is good tho
have a talk to adydas as he had the RSM for a bit - chur chur
MrOizo
Toyspeed Legend
Postby Silent Knight » Mon Apr 03, 2006 6:14 pm
Yea Jason has one two so I'll ask him aswell tonight what the haps is with those.
Cheers boss!! :D
Anyone else with any experience with these?
Maybe I should just get the earlier model and brag about how my car has a 1000HP engine in it.. :P
Silent Knight
Postby Adydas » Mon Apr 03, 2006 6:27 pm
RSM is quoted at +/- 1% or something close to that accurate IF There is no wheelspin UNLESS you use G sensor then again quotes same %.
Naturally you need correct setup, run the test and correctly mount and setup the G sensor.
FWIW..
its good value, id get another.
Adydas
Postby Silent Knight » Mon Apr 03, 2006 6:35 pm
Cliff does the RSM give an estimated HP rating aswell?
Silent Knight
Postby Silent Knight » Mon Apr 03, 2006 6:48 pm
Ok Gentleman thank your time and help.
All my questions have been answered and it seems that the RSM+G sensor will be the best way to go.
Silent Knight
Postby fivebob » Mon Apr 03, 2006 7:35 pm
Either of these units will give farily accurate results except that the RSM will take into account wheelspin if you have the G sensor.
The G sensor in the RSM does not take into account vertical G's from the test section not being on level ground, so it is not really any better in that respect. You will still get variances in the readings if you don't conduct you tests over the same section of road, preferably flat with runs done in both directions and averaged out.
I have used both and prefer the Blitz and it's a more compact unit and easier to install as it only requires Power, Earth and Speed signal inputs.
Postby Silent Knight » Mon Apr 03, 2006 7:50 pm
Hrmmm thanks for the input there fivebob.
This is starting change my opinion then.
The reason I would rather go for the Blitz unit is because of it's small/compact design.
But I do not want to sacrifice reliability etc just for because of the unit's design.
If they both give fairly accurate readings etc then I would much rather the Blitz unit quite personally.
Silent Knight
Postby Wildcard » Mon Apr 03, 2006 9:46 pm
Devils advocate: $253USD will buy you ~8 full dyno runs.... 8)
Wildcard
Toyspeed Founder
Postby Silent Knight » Mon Apr 03, 2006 9:49 pm
Wildcard wrote:Devils advocate: $253USD will buy you ~8 full dyno runs.... 8)
And afterwards I'll only have a piece of paper to show for it.
With this I get digital output and a bling little unit to show off to maH beatches!!! :P
Silent Knight
Postby Adydas » Mon Apr 03, 2006 10:21 pm
you can Reset the G sensor back to 0, so this will make it accurate again even on an angle?
yes no?
as long as your not trying to launch up or down that massive hill in Dunediun.
Adydas
Postby Adydas » Mon Apr 03, 2006 10:23 pm
Oh and dont for get, if u get even cooler hanre you can go to plan b and get an AVCR and even Vtec controller so it all matches etc.
Like transformers MEGA BLING!!
Adydas
