Idling problem
Idling problem
Postby 20v_rollaboy » Sun Apr 09, 2006 1:32 pm
Took the battery out of my 20v yesterday, used it in my other car and then put it back. Problem is now my car idles at 2k when cold and around 1.5k when warm.
Havnt touched anything, except take the battery out and put it back
Anyone have any ideas as to why this is???
Thanks
20v_rollaboy
Postby dazzag » Sun Apr 09, 2006 1:38 pm
when you removed the battery the computer lost its memory so its trying to figure out what speed to idle at. it should come right
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby slighty_sykotic » Sun Apr 09, 2006 10:58 pm
wat the hell?
The computer doesnt lose anything.
I would say if anything has changed, its becuase you have knocked something and made a vacuum leak.
--Sykotic
slighty_sykotic
Postby FLAWLES » Thu Apr 13, 2006 12:09 pm
when you disconnect the bat u do lose the memory in the ecu
u only need to dissconnect it for 10sec
FLAWLES
Re: Idling problem
Postby trueno_20v » Thu Apr 13, 2006 1:49 pm
20v_rollaboy wrote:Took the battery out of my 20v yesterday, used it in my other car and then put it back. Problem is now my car idles at 2k when cold and around 1.5k when warm.
Thanks
ive taken the battery out of my silvertop hundreds of times and never had a problem :?
ADMIN EDIT: signature too large
trueno_20v
Postby slighty_sykotic » Thu Apr 13, 2006 2:40 pm
FLAWLES wrote:when you disconnect the bat u do lose the memory in the ecu
We are talking about a old ecu here... Explain to me what it loses? The time?
--Sykotic
slighty_sykotic
Postby FLAWLES » Thu Apr 13, 2006 4:07 pm
come on man
think
ecu................................ set fuel maps and ign timing
u reset it buy either disconnecting the power supply " the battery " yopu are wipping all the maps in the ecu... this can cause idol errors and or running rich/lean for a few mins
FLAWLES
Postby 20v_rollaboy » Thu Apr 13, 2006 7:21 pm
This was a problem for a couple of days, not a couple of minutes.
Anyway the problem is now sorta fixed. We retarded the timing a bit and adjusted the screw on the AFM.
Also I think the fact that my VVT pulley is stuffed isnt helping the problem :(
Another problem I might add is that in traffic or when Ive been idling for a while the engine seems to pulse by itself. Like the revs will drop to like 400 and then spike up to 1200. Anyone got any ideas??
20v_rollaboy
Postby Crucible » Thu Apr 13, 2006 8:37 pm
20v_rollaboy wrote:when Ive been idling for a while the engine seems to pulse by itself. Like the revs will drop to like 400 and then spike up to 1200. Anyone got any ideas??
Did you by any chance loose coolant by taking off a hose etc? and yes ecus do loose their memory by disconnecting the battery, well some do anyways :lol:
tnt
Crucible
Real Life Mechanic
Postby 20v_rollaboy » Thu Apr 13, 2006 8:50 pm
I do know that my waterpump is leaking, so I have to top it up everyday because I sit in about 2 hours of traffic each day :cry:
20v_rollaboy
Postby Crucible » Thu Apr 13, 2006 9:02 pm
20v_rollaboy wrote:I do know that my waterpump is leaking, so I have to top it up everyday because I sit in about 2 hours of traffic each day :cry:
Once you replace the pump and top up and bleed the cooling system your idling problem will be no more, its got nothing to do with disconnecting the battery.
tnt
Crucible
Real Life Mechanic
Postby dazzag » Sun Apr 16, 2006 12:13 pm
tnt is spot on. intially i thought it was just cos you had taken out the battery. didnt relise you were loosing coolant. the air in the cooling system will be confusing the idle speed controller
and as for this.
wat the hell?
--Sykotic
??????????? the computer does lose some of its memory
dazzag
