proximity sensors/switches.
Postby barryogen » Thu Apr 13, 2006 1:22 pm
Anyone know where I can buy/get a sensor etc that I can set so that when a device(call it keyobject for future) is within say 10m of my car, it flicks a switch?
preferrably it would throw the switch back when the keyobject moves out of it's range.
preferrably with multiple keyobjects(one for me, one for wifey)
I've tried DSE, and Jaycar*, and also a couple of marine electronics places with no luck. the local auto electricians had no ideas, Repco and Super Cheap said cool idea, but didn't know where to start.
The switch in question would be a two step, one to trigger the central locking, one to trigger the ignition to the on position, start button on the dash. The reason being I'm lazy, and I also want to something different.
Sofar I have thought that I should be able to do it with something as simple as an RFID type device or two, with a reader to throw the switch based in the car.
Thanks in advance.
*Jaycar have RFID gear, but it has ranges like "upto 100mm" so I would basically have to mount it in the door, and if I opened the coor, the car would switch off, so not ideal at all.
barryogen
2ZZ Guru in training
Postby barryogen » Thu Apr 13, 2006 1:39 pm
Just found Jaycar item GG2375
it should be able to be modified to do the job with something like jaycar item LR8820
barryogen
Postby t0ms » Thu Apr 13, 2006 6:42 pm
433 Mhz magicar 2 way alarm systems have a 2 way proximity system built in to their car alarms however the ign on start button thing would be a bit harder.
i would be a little concerned about the range on the jaycar thing. one meter or so would most likely be my guess which would be a pain as you would have to be standing next to it to get it to work
t0ms
Postby barryogen » Fri Apr 14, 2006 11:25 am
The thing is, it could be set to trigger a one way switch, so that when I'm within a metre, it unlocks the car and flick the ignition to on, and then thats it's sole purpose, I could then rig something up to disable them maybe with a better alarm or something.
barryogen
