Making a loom
Making a loom
Postby Zyros » Sun Apr 16, 2006 5:31 pm
Yeah well, just being re-doing the loom to my distributor --> from the ECU..
Any suggestions on what wires to use, how to insulate it.. just some heat shrink? What connector to crimpt onto the 4 wires to connect to distirbutor wires..
And tips for doing this specific part of the loom, thanks.. or if someone is cutting up a loom.. im after the dizzy part to and from the ECU pin.. :P
Zyros
Postby suberimakuri » Sun Apr 16, 2006 7:11 pm
4 wire sheilded... grab off another car with same motor or buy from jaycar.
ground one end of shealth only
suberimakuri
Postby Zyros » Sun Apr 16, 2006 8:35 pm
Karl_Skewes wrote:4 wire sheilded... grab off another car with same motor or buy from jaycar.
Would noarmal wires going from the ecu pin to the dizzy unprotected etc.. possibly be the cause of a misfire?
Zyros
Postby suberimakuri » Sun Apr 16, 2006 8:40 pm
yeah, they should be shielded.
suberimakuri
Postby sergei » Sun Apr 16, 2006 9:16 pm
flexible cored thin coax should do the job (overkill?), it is cheap as nuts, the only problem is to tell apart wich wire is wich (wich can be marked by different coloured usnulation tape etc). Or you could just use shielded audio cable, which is cheap as well...
Postby Zyros » Sun Apr 16, 2006 10:17 pm
sergei wrote:flexible cored thin coax should do the job (overkill?), it is cheap as nuts, the only problem is to tell apart wich wire is wich (wich can be marked by different coloured usnulation tape etc). Or you could just use shielded audio cable, which is cheap as well...
I never knew they had shielded audio cable, unless you mean the stuff like 4gauge wires have with that thick as rubbery insulation?
Whats flexiible cored thin coax anyway :P
Zyros
Postby sergei » Sun Apr 16, 2006 10:29 pm
Isulated and Shielded are 2 different things.
Shield looks like braid on braided hoses, with isulation on top, it shields the electromagneting waves from outside (or sometimes from inside), every conductor carrying current will create electromagneting interference, which will induce currents in wires close by, sensetive input wires need to be shielded, as the currents in sparkplug wires (for example) will induce signal in the distrubutor wire creating various feedbacks and interferences (try placing mic next to speaker), thus making engine run very rough or not run at all (actually it is much more complicated).
http://www.dse.co.nz/cgi-bin/dse.filereader?4441fda208d40f88273fc0a87f99071c+EN/catalogs/CTG0000448
Postby Zyros » Sun Apr 16, 2006 11:01 pm
You have PM.
http://www.dse.co.nz/cgi-bin/dse.storef ... View/W2038
This stuff seem's reasonable.. except everywhere i go DSE say they havent seen this product the useless staff..
Hm, hopefully this solves my issue..
Zyros
Postby sergei » Mon Apr 17, 2006 3:05 am
You can go to pickapart and chop a loom for real cheap (or get a complete thing if you are lucky)...
Postby Zyros » Mon Apr 17, 2006 4:23 pm
sergei wrote:You can go to pickapart and chop a loom for real cheap (or get a complete thing if you are lucky)...
Went today, no car had the loom i needed!! argh, looks like its Dicksmiths to make one using that link, and i guess ill solder some of that insulation and earth it somewhere.. should hopefully do the trick,
Zyros
Postby QikStarlie » Mon Apr 17, 2006 6:01 pm
go to a electrical wholesalers like, ideal or ja russel. ask for some 4 core shielded. say your from some random electrical company and ask for trade discount
QikStarlie
