1s bellhousing fit 3sge?
Postby ps165 » Sat Apr 22, 2006 2:18 pm
just wondering if a bellhousing of a 1S motor would fit a 3S motor? cheers
ps165
1s to with t50
Postby Celica RA45 » Sun Apr 23, 2006 12:38 am
yes a 1s with t50 gearbox will bolt up to a 3sge ,but it would be better with a 2s bellhousing so you can a supra box w57 is the best 1 and has the best ratios
Celica RA45
Postby KinLoud » Sun Apr 23, 2006 7:49 am
Yes - I am running a 1S bellhousing on my W57 behind my gen3 3sge.
You will need to do a couple of things to make sure the clutch will release properly but nothing too hard.
I also have a 1s bellhousing off a 22 spline T50 that will fit any of the S motors including 3sge.
The 1S bellhousings from a W55/W57/W58 etc. are the same as the 1C/2C etc. diesel engine bellhousings (with either a W or a G series gearbox).
Ken
Hamilton
021 408 863
Re: 1s to with t50
Postby ps165 » Sun Apr 23, 2006 12:59 pm
Celica RA45 wrote:yes a 1s with t50 gearbox will bolt up to a 3sge ,but it would be better with a 2s bellhousing so you can a supra box w57 is the best 1 and has the best ratios
its a 1s motor, and a w55 box.
whats the different ratios in the w57. coz with my w58 (behind 2.8L) when in in 5th im always looking for a another gear, i fell like im in 4th, shoud i get a 3.7 diff? is a w55 better (than 57 or 58 ) for anything?
ps165
Postby KinLoud » Sun Apr 23, 2006 6:45 pm
W55 - 3.58 1st gear
Often W55's are found behind 4 cylinder engines - lower 1st gear helps when you have a bit less torque I guess (ask mr toyota).
W57 - 3.28 1st gear over all slightly closer gearing 1st, 2nd, 3rd... 4th and 5th same as W55
W58 - same as W57 except that 5th is 0.78 to keep the revs lower when cruising.
What are your revs at 100kph in 5th?
What does the build plate codes say?
Ken
Ham
021 408 863
