MOMO Boss kit wont turn off indicators
Postby TruenoBZG » Sun Apr 23, 2006 6:24 pm
For my AE111, Ive been told its a common hiccup with installing boss kits, how can I figure out to position it right so it will turn my indicators off after turning corners?
Ive tried a few different positions but to no avail - and now its getting extremely annoying because I have to pull my wheel off everytime I want to change it
Also, are there any surrounds I can buy to cover the small gap which the kit doesnt cover around the steering column?
Thanks
'96 Trueno BZ-G
TruenoBZG
Postby slighty_sykotic » Sun Apr 23, 2006 6:44 pm
You might not have the holes in the back of the bosskit in the right place to line up with your indictators.
IE, you might need to drill need ones, or enlarge the ones you already have.
In my HKB boss kit I had to drill new holes, as the ones that were already there were FAR too close together.
Try it again, and if you can't get the pins on the stalk thingee to line up with the holes, measure the distance between the pins, and then the holes on the boss kit, should be the same.
--Sykotic
slighty_sykotic
Postby TruenoBZG » Sun Apr 23, 2006 6:50 pm
So the pins on the stalk/column should line up with the hole/gap in the boss kit?
Also, there is only ONE pin on my column, not two.....
Also, when I first tried it, i remember it turned one side of the indication off, so I know its working OK, I just need to get it right.
'96 Trueno BZ-G
TruenoBZG
Postby slighty_sykotic » Sun Apr 23, 2006 6:54 pm
I would say, take the boss kit off, put indictors on, and try to turn that pin around until it clicks the indicators off, i would say you have moved that pin right around, so that it doesnt go far enough to turn one side off. I would guess you would have to spin the pin a full circle (or two) one direction to get it to evenly click the indicators off each side.
lol, did that make sense?
And yup, the pin should go into the hole in boss kit
--Sykotic
slighty_sykotic
Postby TruenoBZG » Sun Apr 23, 2006 6:59 pm
slighty_sykotic wrote:I would say, take the boss kit off, put indictors on, and try to turn that pin around until it clicks the indicators off, i would say you have moved that pin right around, so that it doesnt go far enough to turn one side off. I would guess you would have to spin the pin a full circle (or two) one direction to get it to evenly click the indicators off each side.
--Sykotic
Ahh cool man thanks for that explanation, its getting a little clearer...
So if i turn that pin around, it should turn the indicators off, WITHOUT my car being turned on?
Thats all I really need to know because I can figure it out from there, I didnt realise I could activate that pin that turns them off even when my car wasnt going...
I cant remember the pin being able to be turned around actually.... but i think the plastic outside it did, which didnt turn them off...
'96 Trueno BZ-G
TruenoBZG
Postby GGnz » Sun Apr 23, 2006 7:04 pm
I done a Momo kit. Was a real pain in the arse. If you have no intentions of removing the wheel just glue the pins in the holes of the boss kit lol. That works...
GGnz
Postby slighty_sykotic » Sun Apr 23, 2006 7:07 pm
Its a mechinal (man my spelling is shocking) thing, so yeah, it won't need power to work, as the pin goes around it "pushs" the indicator out of its slot thing and returns it to center making the indicators turn off.
And yes, i think you have to push the pin/plastic IN as you turn to make them click off (this is if you have no boss kit on).
It might be fairly hard to click them off just turning the pin, as the leverage will be small.
If it all fails, can you get a pic of it to chuck up?
--Sykotic
slighty_sykotic
Postby slighty_sykotic » Sun Apr 23, 2006 7:08 pm
GGnz wrote:I done a Momo kit. Was a real pain in the arse. If you have no intentions of removing the wheel just glue the pins in the holes of the boss kit lol. That works...
Lol, rangi time is it..
Thats rough man... lol.
Just drill a new hole if it doesnt line up.
--Sykotic
slighty_sykotic
Postby TruenoBZG » Sun Apr 23, 2006 7:10 pm
hehe rangi time - what if I wanted a new steering wheel??
I'll post a pic tommorow of it doesnt work...
cheers!
'96 Trueno BZ-G
TruenoBZG
Postby slighty_sykotic » Sun Apr 23, 2006 7:15 pm
He means just the boss kit, so I guess you could do that, you would still be able to bolt new wheels onto the kit.
--Sykotic
slighty_sykotic
Postby TruenoBZG » Sun Apr 23, 2006 7:26 pm
ah right, i suppose that could work... :?
'96 Trueno BZ-G
TruenoBZG
Postby haydo » Tue Jul 24, 2007 2:50 pm
do you mean those two little bumps you can see ... are they what fills the wholes in the boss kit to flick the indicators off?
my bumps won't fit in mine :(
haydo
haydo
Postby slighty_sykotic » Tue Jul 24, 2007 4:21 pm
yup.
You will need to drill out holes that fit the bumps.
slighty_sykotic
Postby haydo » Tue Jul 24, 2007 4:26 pm
in the boss kit?
haydo
Postby slighty_sykotic » Tue Jul 24, 2007 4:32 pm
yeah, in the back of the boss kit so that the pins/bumps fit into the holes
slighty_sykotic
