sergei wrote:just having shifter will not help, if you are going to use AE111 shifter you will need the cables as well. Or you can modify (file litle bit so it will allow more movement). with gearbox mount plate from AE101 I had to flatten it out and drill holes in it so will be possible to use AE101 mount. The AE111 mount is completly different.
bluemaumau wrote:800?!
you can get e58s for like 300-400
whats so great about 6 gears anyway, just another gear change...
gasman wrote:bluemaumau wrote:800?!
but if i get the e58 i will need new shafts wont i?
