Headgasket 4AGE 20 Valve
Postby opticalblue » Fri Apr 28, 2006 4:34 pm
hey whats the best headgasket to use for a 4AGE 20 Valve Turbo with forged pistons
opticalblue
Postby Bazda » Fri Apr 28, 2006 6:37 pm
depends what compression you want.
So measure the cc of the head chamber, measure the cc of the piston at tdc if there is anything there to measure or it could be sitting flat, and take into account how many cc's the head gasket will take up, eg measure the head gasket diameter and times that by how thick ur head gasket is, standard is 1.2mm, you can get either a 0.8 or 0.5mm metal one from TRD.
then search the net for a engine compression calculator and you put those figures into it.
Postby Mr Revhead » Fri Apr 28, 2006 9:32 pm
fyi 20v TRD gasket is only avail in 0.8mm :wink:
Postby Bazda » Fri Apr 28, 2006 9:37 pm
Mr Revhead wrote:fyi 20v TRD gasket is only avail in 0.8mm :wink:
how did i get a 0.5mm one.....
Postby Mr Revhead » Fri Apr 28, 2006 9:39 pm
itll be a 16v one
Postby vvega » Fri Apr 28, 2006 9:59 pm
um no its not :D
16v ones have a very differnt water hole setup
v
vvega
Postby matt dunn » Fri Apr 28, 2006 10:02 pm
maybe they sold it to you as a 0.5 when it was a 0.8?
I use a standard genuine item in mine.
Matt
Postby vvega » Fri Apr 28, 2006 10:11 pm
ill have to tri to remeber who i got it thoughpritty sure it was tnz
hell i might have still got the package somewhere
BTW i belive that bazz would have measured it when doing his compression ratio :D
v
vvega
Postby Mr Revhead » Fri Apr 28, 2006 10:30 pm
has it still got the rivets holding it together?
some ppl seperate the sheets making it thinner
http://trdparts.jp/english/parts_engine-4a-g20.html
Postby opticalblue » Mon May 01, 2006 8:07 pm
going abit off topic guys... so anymore suggestions...
opticalblue
Postby Grrrrrrr! » Tue May 02, 2006 12:48 am
The suggestion by Bazda is the right one... figure out what thickness you need to get the compression you want then find a reputable supplier that makes them in that thickness... (Like Toyota Genuine or TRD ;) )
Or just get the TRD one and machine the head/pistons to get the compression you want.
Grrrrrrr!
