GT STARLET HELP
GT STARLET HELP
Postby drift_taxi » Wed May 03, 2006 11:47 pm
im thinking of buying a gt starlet. i saw it and when the guy went to start it the engine would kind of turn over but not start. what could that mean? and when it did start it blew blue smoke (kind of lokey blueish) what does that mean? (im kind of guessing that would be eithere the head gasket or the seals) is so how much would either cost to fix.
this is ergent so if you have any information that i requere please email me at go_cky2k@hotmail.com
thanks alot.
drift_taxi
Postby bluemaumau » Wed May 03, 2006 11:48 pm
clicking: bad battery or starter motor.
blue smoke: usually turbo seals on the way out
Postby dotdog » Thu May 04, 2006 7:52 am
Yea clicking and strugling to turn over will be a dead battery, But blue smoke isnt the turbo they smoke thick white stinky smoke when the seals let go, blue is more likely to be ya rings or a shaged headgasket, and if its only on start up ya valve guild seals.
If its a headgasket/vavleguild seal thats prob the better part of $1k and if its the rings kiss goodby to $2k+
dotdog
Postby Jazza » Thu May 04, 2006 8:30 am
I thought blue smoke was the turbo... :?
Jazza
Postby Elmendorf » Thu May 04, 2006 10:53 am
Blue smoke =
PCV valve (cheap to fix)
Valve stem seals (reasonably cheap to fix if bought as part of engine gasket set)
Headgasket - cheap to buy even aftermarket
Rings - not very dear either just expensive to replace due to labour costs
Valves - getting up there to buy and replace
White smoke =
Turbo (i know been thru 3 turbos already)
Hard to start,
Battery
Starter motor
dizzy
fuel pump or injectors or both (mine use to be hard to start on facto injectors and pump)
If yur after prices for stuff contact Mr Revhead hes the official guy here.
Hope this helps. Feel free to email me if you need more info
Elmendorf
Postby drift_taxi » Thu May 04, 2006 12:09 pm
sweet thanks guys. what do you think would be a resanble price to pay for a gt starlet in the worst case scenario?
drift_taxi
Postby FrEsH » Thu May 04, 2006 12:22 pm
3g maybe its hard to say without knowing the exact problems and condition....most stocksih GT's starlets go for around 5-6k so yeh...maybe take the car to your local mechanic and get him to check it over and identify the problem so you know exactly what your in for
FrEsH
Postby drift_taxi » Thu May 04, 2006 12:29 pm
yep thats what i might do eh
thanks.
drift_taxi
Postby bluemaumau » Thu May 04, 2006 12:41 pm
are you sure, my mate put a bung turbo on his teg andn it blew blue smoke constantly, white smoke means its only got a few hours to live i thought (turbo smokes this is, not engine)
Postby Elmendorf » Thu May 04, 2006 7:15 pm
Well all my turbos blew white smoke for ages before i replaced them, blue smoke has so far only been either pcv valve or valve stem seals. I dont know anything about hondas (other than there is now one less thanks to the womans one that just went up in smoke on Princess street :lol: ) so I dont know what any of their wear indicators are. Having had my GT for 5 years now I know what the wear indicators are and can advise people accordingly on them 8)
Personally I wouldnt pay much for it, any more than 4K for a gt starlet stocka or not is a rip. But yes take it to a mechanic you know and trust or if you belong to the AA get them to check it out.
Elmendorf
Postby dotdog » Thu May 04, 2006 7:19 pm
Yip I totally agree with harlet turbos smoke white smoke, Ive done 5 so far, everyone of them was thick white some. Headgaskets can be pricy jobs if you are paying someone todo them and the head needs machining
dotdog
Postby TrouserFxGt » Thu May 04, 2006 8:41 pm
blue smoke = oil that has been through the combution process.
white smoke = oil that hasn't.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby slighty_sykotic » Fri May 05, 2006 11:14 am
Very good, and that can mean turbos can smoke ethier blue OR white.
If the seal on the compresser side is leaking, you get blue smoke, as the oil is being burnt in motor, and if its the exhaust side, its white smoke.
(my turbo seal let go on compresser side).
Easy way to tell, undo a intercooler pipe and lok for oil. If there is a fair bit of oil its a leaking seal on the compresser side causing the smoke, if not, then you will have to look further.
--Sykotic
slighty_sykotic
Postby dotdog » Fri May 05, 2006 6:11 pm
One of my turbos let go on the compressor side, didnt smoke tho, just filled the cooler up with oil and ran like a big bucket of shit
dotdog
Postby drift_taxi » Fri May 05, 2006 9:42 pm
hi bradly! you know who this is dont you...i got your valentine.lol
yeah i was thinking of getting a starlet but the guy doesnt seem to want to reply so screw him.
drift_taxi
