Can i run a 2jzge with 20valve quads on a link??
Postby CozmoNz » Mon Apr 24, 2006 11:03 pm
Dont m3's have 6 ITB's?
could yaknow.. sell your left leg....
Rayne For President!
CozmoNz
Postby mikuni » Sun May 14, 2006 5:08 pm
Don't give up man, you will be able to do it. It has been done before. Don't take the example of a ford engine as meaning that it can't be done. Trying to tune 3 carbs will be a real hassle to get reliable in my opinion. Just for a little encouragement have a look at this.
http://www4.tpgi.com.au/users/loats/tec ... jzge02.jpg
mikuni
Postby matt dunn » Sun May 14, 2006 5:36 pm
mikuni wrote: Don't take the example of a ford engine as meaning that it can't be done.
Exactly. Even though it did not work for us,
every setup will be different, and the only way to tell is to try.
Postby KE20 » Sun May 14, 2006 11:21 pm
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Postby 4000GT » Mon May 15, 2006 11:14 pm
Go for the new Link G2 with user definable tables if you want factory type running tune. I am runing a V5 LEM in my car with ITB's on a black top.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby mjrstar » Thu May 18, 2006 5:11 pm
Personally i'd be selling the itb's and going for a large single it'll make the manifold so much easier and a 80mm tb and tps from an 4 litre falcon won't set you back more than about $80.
IMO it'd be cool to say you had 6 throttle bodies on your car but I can't see any real gains in it..
Matt
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby 4000GT » Thu May 18, 2006 5:30 pm
mjrstar wrote:Personally i'd be selling the itb's and going for a large single it'll make the manifold so much easier and a 80mm tb and tps from an 4 litre falcon won't set you back more than about $80.
Matt
Yes its harder to tune, but if you have the right ECU, such as the Link G2, then its worth the extra tuning time. The response from ITB's is awesome.
4000GT
Postby iainous » Sat Jun 17, 2006 12:19 pm
Im looking at doing this on my 2jz as I have some 20V ITB lying around, will be keeping it NA tho, anyone know of any links to websites or forums where this has been done?
iainous
