I had Platnums in the caldina when i got it, i had to get them replaced about 3 months back but only get iridiums, will never go there again, using platnums again... happy as larry
Spark Plugs
The resistor located between the centre electrode and the centre axis enables Genuine Toyota Spark Plugs to prevent interference with on-board electronics, such as the radio. Non-genuine spark plugs without resistors fail to reduce interference with electronics.
Genuine Toyota Spark Plugs feature a U-Groove ground electrode which optimises engine performance, including starting, acceleration, fuel economy and power.
Toyota uses reliable materials and precise construction methods to create its spark plug housings. The result is stable performance and long life. Genuine Toyota Spark Plug housings also have a high rate of thermal conduction, ensuring that they are always at the ideal temperature. Without proper heat conduction, spark plugs tend to run too hot or too cold, causing engine misfires or pre-ignition which often leads to engine damage.
To work efficiency, engines must have spark plugs with the appropriate heating range. If the range is inappropriate, the plug may fail to ignite, resulting in poor starting, reduced performance on uphill climbs or when carrying a heavy load, and increased fuel consumption.
edwagon wrote:I don't have a high opinion of bosch plugs, and as above, champion don't seem to be much good either!
NGK all the way!![]()
OEM plugs will be good too tho...
You can take about 20 different NGK plugs, cross them over to a bosch or a champion and they will all cross over to 1 plug.
There range is not big enough, and the champions don't take the heat when tey are way down in the head of a jap DOHC
WanaGo wrote:where did you find that from?
Is there a whole lot of technical stuff listed somewhere for the gt-t?
ta
WanaGo
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
