Manual Boost Controllers
Postby solitaire » Tue Jun 13, 2006 8:40 pm
Hey Guys
I was gona save up and get an electronic boost controller but ive been told if im not planning to play with the boost i can just get a manual one.
I'm doing the resistor trick with the fuel cut but my question is....
1. Is this any good? seems cheap but he has covered all the base points... http://cgi.ebay.com/ebaymotors/Voodoo-III-MBC-Manual-Turbo-Boost-Controller-0-30-PSI_W0QQcmdZViewItemQQcategoryZ33742QQihZ019QQitemZ8072793856QQrdZ1
2. Anyone know of a cheap place to buy them?
3. Does anyone think that a manual boost controller is a seriously bad idea?
and
4. How high would you boost a gen1 mr2?
thanks guys
AE92, KZJ120, KDJ120
solitaire
Postby FST4RD » Tue Jun 13, 2006 8:58 pm
When I had my MR2 I ran a Gofast manual boost controller, worked well with minimal drop off (normally shot up to bout 14psi and backed off to 13psi), used the same one on my GSR and worked a treat!!!
As for boost levels, I never had mine above 14psi to be safe, if you still got the factory turbo it's not to much good after that anyways I dont think.
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Chickenman » Tue Jun 13, 2006 9:22 pm
Even 10lbs with a ball and spring controller will be a huge differnce as they eliminate wastegate bleed (mostly).
Baby Jesus
Chickenman
I Am The Walrus!
Postby solitaire » Tue Jun 13, 2006 9:49 pm
FST4RD wrote:When I had my MR2 I ran a Gofast manual boost controller, worked well with minimal drop off (normally shot up to bout 14psi and backed off to 13psi), used the same one on my GSR and worked a treat!!!
Your a bloody wealth of information arnt you? :D i think you have posted in every thread i have created.... thanks mate!
you just got it in a local shop to you i assume?
solitaire
Postby slighty_sykotic » Tue Jun 13, 2006 9:55 pm
I'm not saying they are bad, (cause i've never used one), but do they give you an advantage with spool up times?
Because I think that is a major plus for an EBC, is the fact that the wastegate is SHUT until the boost level is reached, not slowly opening.
Am interested to hear opions on this...
(need one for my honda city turbo :P, got a gready profec in my 4agte).
--Sykotic
slighty_sykotic
Postby FST4RD » Tue Jun 13, 2006 10:04 pm
http://www.trademe.co.nz/Browse/SearchR ... 0001-0877-
Try trade me there's heaps there.
http://www.trademe.co.nz/Trade-Me-Motor ... 473350.htm
This is the one that i had in 2 of my cars and it went really well
Not to sure bout the spool up times, I had an EBC in a previous car and the only advantage about it was the high/low setting in the cabin and not having to get out and adjust it under the bonnet.
Also try Jaycar as well, they do a cheap EBC that you can build yourself and my friend who has one said thats it's great
FST4RD
Postby solitaire » Tue Jun 13, 2006 10:05 pm
slighty_sykotic wrote:I'm not saying they are bad, (cause i've never used one), but do they give you an advantage with spool up times?
--Sykotic
Chickenman wrote:Even 10lbs with a ball and spring controller will be a huge differnce as they eliminate wastegate bleed (mostly).
Hmm... good point... i think chicken man says that it doesnt slowly open? maybe?
Is your honda city the one painted in chameleon?
solitaire
Postby solitaire » Tue Jun 13, 2006 10:15 pm
FST4RD wrote:http://www.trademe.co.nz/Browse/SearchResults.aspx?searchtype=GENERAL&searchstring=boost+controller&searchregion=100&mcat=0001-0877-
Cool... what does "gated mean"?
Has anyone used a voodoo boost controller? dirt cheap
solitaire
Re: Manual Boost Controllers
Postby Al » Tue Jun 13, 2006 10:16 pm
solitaire wrote:I'm doing the resistor trick with the fuel cut but my question is....
Pull the hose out of the bottom of your boost pressure sensor and plug the hose up leaving the sensor open to the air. No more boost cut for free :)
Al
Postby solitaire » Tue Jun 13, 2006 10:17 pm
Hmm... that would allow the engine to boost to 20psi without fuel cut? cos i like my pistons inside my block... :twisted:
solitaire
Postby Al » Tue Jun 13, 2006 10:22 pm
Yeah only if your boost controller fails.
Al
Postby FST4RD » Tue Jun 13, 2006 10:26 pm
Yeah there's a hose in the back of the engine bay that you can pop of and quicker than you can say "who's your daddy" no fuel cut.
As far as i'm aware there's 2 types of manual controllers (possibly more) one has a spring and a ball bearing and the more you wind it out the more the ball bearing moves meaning more pressure, these are great as long as the ball bearing don't jam up like mine did..... (easily fixed but a pain in the rear) like the turbosmart one.
The other type has a needle type thing the the more you wind it out the more air can be bleed of (like the GFB one)
I've had both and both worked perfectly fine considering i only ran max 14psi. I think most people would tell you they're no good for anything above that though.
FST4RD
Postby solitaire » Tue Jun 13, 2006 10:36 pm
FST4RD wrote:Yeah there's a hose in the back of the engine bay that you can pop of and quicker than you can say "who's your daddy" no fuel cut.
So the ball and spring is better yeah? can you tell if this one is ok? in you opinion of course... wont come hunt you down if my engine blows... but you obviously know your shit :D http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Turbos/auction-59864101.htm
solitaire
Postby crnkin » Tue Jun 13, 2006 10:44 pm
I have ball and spring, cost me $30 off trade me. Absolutely no boost spike, hits full boost hard and fast (faster that without) and provide adjustment to over 25 psi (my intercooler hoses blew off)
sweet as
deaf_homo "currrently yes"
crnkin
Postby FST4RD » Tue Jun 13, 2006 10:49 pm
Yeah thats damn cheap!!!! I'd go for that one if i didn't already have one for the old staz (well at the moment the turbo's a bit poked and only free boosts at 12-13psi anyways :lol: )
But 20psi on the factory turbo :? not unless you have the C20B off the gen 3 + MR2's
FST4RD
Postby solitaire » Tue Jun 13, 2006 10:49 pm
crnkin wrote:(my intercooler hoses blew off)
sweet as
cool :lol:
setiing them up is simply going for a drve yeah?
solitaire
Postby solitaire » Tue Jun 13, 2006 10:51 pm
FST4RD wrote:Yeah thats damn cheap!!!! I'd go for that one if i didn't already have one for the old staz (well at the moment the turbo's a bit poked and only free boosts at 12-13psi anyways :lol: )
=) ha i was planning no more than 14... you agree?
solitaire
Postby slighty_sykotic » Tue Jun 13, 2006 11:04 pm
solitaire wrote:Is your honda city the one painted in chameleon?
I wish :(
Mine has no doors and only 3 wheels at the moment..
But you just wait!
--Sykotic
slighty_sykotic
Postby solitaire » Tue Jun 13, 2006 11:06 pm
I wish :(
But you just wait!
--Sykotic
look on the bright side... at least its only half a honda now! :lol:
solitaire
Postby crnkin » Tue Jun 13, 2006 11:57 pm
sweet as
cool :lol:
nah, 15 for 2 dollar hose clamps :)
crnkin
