gepsk8 wrote:
my mates old man run a reduction start on his race car blow to lots of plastic gear runners. but hes got 13-14:1 runs it on av gas.
ChaosAD wrote:Yeah that will have something to do with it as the bese timing has been retarded 5 degrees. need to get the megasquirt doing timing.
But will the redtop starter be sweet mounted under the ex mani?
ChaosAD wrote:when the engines warm the starter doesnt have enough grunt to get the crank past TDC more than a couple of times.
ChaosAD wrote:Yea but even when cold the starters shite. Is the silvertop starter the same as the redtop? or is the redtop the only one to go for?
