4agze injector plugs
Postby SpeedRacer » Wed Jun 14, 2006 9:08 pm
ok, had a quick little search which turned up empty so here goes *prepares for bite*
are 4age injector plugs the same as 4agze injector plugs? i hav a 4age loom i wanna chop up to use with a link and 4agze injectors but dont wanna chop up my 4agze loom because its going to a new home.
so do I have to use my 4agze injector plugs with my 4agze injectors or will the 4age plugs be fine?
also what other injectors (that are bigger) could i use on my redtop?
Sinister Sleeper 35
SpeedRacer
Postby Caveman » Wed Jun 14, 2006 11:30 pm
small port 4age plugs are different to gze ones. You could probably cut up the plug somehow to make it suit. Best way is to use gze ones. There are probably others that fit, just try around pick-a-part
edit - these are ae101 gze injectors im talking about :D
AW11 Track Toy
Formerly known as 1998
Caveman
Postby SpeedRacer » Wed Jun 14, 2006 11:39 pm
what about big port ones?
Sinister Sleeper 35
SpeedRacer
Postby ants_ae92 » Thu Jun 15, 2006 9:16 am
Yes big port ones fit, I tried takingthe plug off one of my big port injectors and plugged it onto the 4agze injector.
Although that was from a bigport 4agze.
Just try/test it if you have the loom and injectors
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby AE86fan » Thu Jun 15, 2006 12:32 pm
Yep I have the same problem, blue top 4age plugs do not fit gze injectors, does anybody know what other plugs will fit, is a gze injector generic with other plugs, ie mitsi??
1984 NZ AE86
AE86fan
Postby crnkin » Thu Jun 15, 2006 12:52 pm
any plug in a car later than bout 1989 will fit, i got mine out of a camry, 8 bucks for the lot from picka part.
And car denso equiped has them ie mitzi, mazda etc
deaf_homo "currrently yes"
crnkin
Postby ants_ae92 » Thu Jun 15, 2006 1:06 pm
There you go, mine is ae92 redtop loom, and those plugs fit a ae92 4agze big port.
So plugs from an ae92 should fit, should be best to try them out.
ants_ae92
