MrBob wrote:hello. Im running a pfc with the boost conrol kit (s-avc soleniod), and external wg. Ive been told that it will not function correctly with an external wg. Anyone had any experience with this combination ? is there a different way to plumb the solenoid when using an external wg ?
its doing a very poor job of controlling boost so far.
any help appreciated
thanks !
Yes, yes there is
Pressure feed --> TEE PIECE ---> one line to solenoid then to the top of the WG, OTHER line goes straight to the bottom port of the wastegate. This only applies to electronic controllers.
With a manual controller, it just goes to the bottom port only - as you already know.
Also, make sure when you do that, let it know its controlling an external wastegate. I don't have personal experience with the PFC boost control, but the AVCR needs to know how you're doing things and I'm assuming it works in the exact same fashion, it'll be in the options menu
somewhere
