old schooler wrote:YOO!! 330kW on standard cams??? thats bloody awsome.
have a hunt around for some aftermarket cams, mainly coz its force induction i dont think that cams with higher lift will do much for you, so just go for more duration. (someone correct me) standard Blacktop cams are 256 duration (advertised) with 8mm lift? might be silvertop specs
either way, going longer duration holds valves open longer and keeping the lift the same keeps air speed up so torque at slow speeds isnt lost...too much (when compairing it with more lift)
dont go too massive with cams too as you will loose bottom end torque and dump it higher up in the revs. may be fun on a dyno and flat out racing (on a race track, of course) but no fun for round town, or even taking off from rest. thats worst case tho, aftermarket cams are pritty cool in saying what they do and where power band is.
ALSO! dont scrimp and put cheap sh*ty valvesprings in it or you will be back where you are now! oh and get new shims as well.
Usually this all comes with the kit. kelford do cams, shims, springs ect for around $1200ish (?) then you got to get someone to fit them, so you got to take the head off. (port match time maybe??)
NO standing on what you have done intended, you have done remarkably well to get that much grunt out of 1800cc on standard cams....well done.
hope this again helps
old schooler wrote:sorry, so you are not greedy and want more.
if its valvesprings the head has to come off.
simple.
and if you dont want that power, wind ya boost back to 10psi. it will last longer without breaking....but you are adicted to it and will always want 25+psi/330kW. so are you going to live with less but reliable grunt or more ruthless, big dollars to maintain, beast?
Bazda wrote:Then hope nothing else goes wrong and I can take it to the drags soon
no_8wire wrote:Cool...nothing I need to worry about, because
1: I will not be making as much crazy power
2: I dont have powersteering...
Good you found the source though...
slighty_sykotic wrote:no_8wire wrote:Cool...nothing I need to worry about, because
You have a water pump and cam belt though.....
That key way drives both of them... at least the cam belt (if the 7a's dont have a belt driven water pump).
--Sykotic
pc wrote:I would suggest removing power steering, but with that power if you have an LSD the torque steer might snap your arms off.
make the belts looseish maybe?
Mr Revhead wrote:yeah with that much grunt itll just spin both wheels so fast there will be an allmost instant bed of molten rubber for the tyres to spin freely on
Bazda wrote:last boost of the night dropped to 3 cylinders Embarassed Not too sure why yet
escortman wrote:hey i asked if i could look at ur mota last nite in town so mean
was it on 3cyl wen u left i thought it sounded a lil sick
