4agze fuel pressure?
Postby FLAWLES » Thu Jun 29, 2006 5:14 pm
ok
im running a rising rate fuel press reg
i wont to no
A) what would be the correct fuel pressure for these things
" i am running 11/12 psi. at the mo i think i may have it to high i.e round abouts 35psi to about 40 at idol i cant remember
i think this may be to high :oops:
and
B) can some1 please tell me the advantages to having one on your engine?
thanks
FLAWLES
Postby l1ttle_d3vil » Thu Jun 29, 2006 7:45 pm
standard 4age is about 38psi - 42psi I think.
Re: 4agze fuel pressure?
Postby Crucible » Thu Jun 29, 2006 7:55 pm
FLAWLES wrote:B) can some1 please tell me the advantages to having one on your engine?
They increase rail pressure at a given boost level. It means more fuel flow through the injectors so you can up your boost a little and keep the a/f ratio correct to prevent a lean condition. Cheap way to keep the a/f right without going to a link etc etc.
Crucible
Real Life Mechanic
Postby FLAWLES » Thu Jun 29, 2006 8:44 pm
l1ttle_d3vil wrote:standard 4age is about 38psi - 42psi I think.
wicked thanks man
so would would be a safe psi to place it to?
FLAWLES
Postby gepsk8 » Thu Jun 29, 2006 8:50 pm
3 bar 45 psi + if u wana run more boost, but u need to upgrade the pump after 3 bar.
gepsk8
