Bluetop v's Smallport
Postby Maxwedge » Thu Jul 13, 2006 11:41 am
I have two complete engines for a AE82 FXGT, a bluetop and a smallport. I wish to do some basic mods, TRD 0.8 gasket, ARP rodbolts, filter, extractors, rings, bearings and cams around 264 from Kelfords. Which engine would perform better in both torgue and HP figures- I am using the car as a club car doing hillclimbs etc
Maxwedge
Postby mr pad » Thu Jul 13, 2006 1:10 pm
smallport
mr pad
Postby Jebus » Thu Jul 13, 2006 2:08 pm
Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport Smallport
Jebus
Postby RED TOP MR 2 » Thu Jul 13, 2006 2:47 pm
SSSSSSSSSMMMMMMMMMAAAAAAAAALLLLLLLLLLLLLLLLLLLLLLLL PPPPPPPPPPPPPPPPOOOOOOOOOOOOORRRRRRRRRRRRRRRRTTTTTTTTTTTTTTT
RED TOP MR 2
Postby crnkin » Thu Jul 13, 2006 5:26 pm
small to the port sizing yo
deaf_homo "currrently yes"
crnkin
Postby RedMist » Thu Jul 13, 2006 5:29 pm
I'm going to buck the trend here and go.
Smallport.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby B1NZ » Thu Jul 13, 2006 6:57 pm
Lets play hangman:
S _ _ _ _ _ _ _ _
i've given you the first letter to get you started :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby evil_si » Thu Jul 13, 2006 7:38 pm
hmmm ill go with every one else on this, SMALLport
evil_si
Postby gepsk8 » Thu Jul 13, 2006 7:45 pm
u after torgue? or HP?
torgue go with smallport (which i think u want as ur doing hillclimbs, etc)
hp then go bigport as u can get more hp out of, but u loose torgue as tvis is normal removed when paying with cams.(normally get higher hp with higher spec motors)
i would go with s/port but its all up what your going to just the motor for in the end.
oh yeah, blah blah blah it an opnion
gepsk8
Postby RedMist » Thu Jul 13, 2006 8:09 pm
gepsk8 wrote:hp then go bigport as u can get more hp out of,...
Ummmm I have microport, ports smaller than smallport and I run 177.5hp at the wheels NA. The only circumstance I can see you running out of flow on a smallport is if you are running over 250hp. Even then I'd probably still use a smallport head and hog it out until I got the required flow.
Smallports seriously rock. For all out no money concern, race engines you simply can't beat it for a base. For a standard road engine its probably just pipped at the post by the 20 valves, but even then its debatable.
RedMist
Postby crnkin » Thu Jul 13, 2006 8:15 pm
And thats due to c/r, not neccesairly the flow either.
The best engine's arent opinion, they're fact
SMALLPORT
crnkin
