Like the subject states i have a 1985 auto aw11 mr2...
Just took my aw11 out for a drive to grab some supplies and something strange happened...
While cruising at 50k i noticed the speedo needle started wobbling rather dramatically. I slowed down to around 40 but the needle wobble got worse if anything. Then, after speeding back up to 50 the needle all of a sudden dropped to 0 and has stayed there ever since. After this occured the light indicating overdrive being on started to flash even when off. When I select overdrive to be on it stays orange, but when switched back to off it flashes off and on once again.
The performance of the car doesn't seem to have been affected. I am not sure if this is related, but i have a rather noticible shudder of the steering wheel when going over 90km. I have had the wheels balanced twice, so its not that...was going to get this sorted at the end of the month but due to the speedo needle problem it seems smart to start to sort this now.
Any ideas?
