vsv in mr2
vsv in mr2
Postby avinesh » Sun Jul 16, 2006 7:48 am
hey guys just wanted to know if disabling vsv in a mr2 without boost controller will cause any problems, my car seems to boost 13.5psi without boost contoller.....
avinesh
Postby AJz » Sun Jul 16, 2006 11:16 am
wat mods are done to your car ??? and what gen mr2 have you got???
I had vtax :(
AJz
Postby Al » Sun Jul 16, 2006 1:39 pm
Have you got an aftermarket exhaust? That will make the stock ct26 creep up a bit. 13.5psi is fine.
Al
Postby avinesh » Sun Jul 16, 2006 3:56 pm
Al wrote:Have you got an aftermarket exhaust? That will make the stock ct26 creep up a bit. 13.5psi is fine.
does the trust exhust come standard on mr2 turbos.....
avinesh
Postby Alex B » Sun Jul 16, 2006 4:14 pm
Since when has trust been a toyota genuine part :?:
No, no it isnt factory...
Postby avinesh » Sun Jul 16, 2006 4:29 pm
pyro_sniper2002 wrote:Since when has trust been a toyota genuine part :?:
kool that means the exhust is aftermarket coz it says trust japan on it an yea i disabled the vsv an the car still boost 13.5 psi is that normal coz i heard the boost will fall to 7psi if i disable vsv without a boost controller.....
avinesh
Postby Al » Sun Jul 16, 2006 6:31 pm
Yeah I'd say the exhaust is the reason it creeps up. If your car was 100% stock with the t/vsv connected and the car is up to temp, outside air isn't freezing and the ecu detects no knock it should boost up to 11.8psi. When the t/vsv isn't operating or disconnected it should provide actuator controlled boost of ~7psi.
Al
Postby Akane » Sun Jul 16, 2006 7:30 pm
avinesh wrote:does the trust exhust come standard on mr2 turbos.....
Suprised nobody detected the sarcasam.
Postby avinesh » Sun Jul 16, 2006 7:46 pm
Al wrote:Yeah I'd say the exhaust is the reason it creeps up. If your car was 100% stock with the t/vsv connected and the car is up to temp, outside air isn't freezing and the ecu detects no knock it should boost up to 11.8psi. When the t/vsv isn't operating or disconnected it should provide actuator controlled boost of ~7psi.
ok what i did was disconnect the hose that goes to the t/vsv an block the hose goin to it.....but i left the line comin out of the wastegate unblocked, should that cause the car to run at 7psi coz i read that the vsv is what causes the car to run at 7psi in some conditions by closing up.....
avinesh
Postby Al » Sun Jul 16, 2006 8:21 pm
Yep but your exhaust will cause the turbo to flow more than the wastegate can handle, so it will creep up regardless.
Al
