if only it was that easy... those sort of things dont exist these daysKinLoud wrote:Maybe get an AE86 dash
johntramp wrote:Cheers.
I see you have a similar engine. Did you use the unit inline with the cable in your Corolla?
Is there any benefit for the ECU to have an accurate reading?
johntramp wrote:is the speedo cable out of the gearbox 1:1 with the driveshaft?
johntramp wrote:I have an ae85 dash which doesn't have the speed signal. Approx how many pulses are there usually? I just want to trick the ecu into thinking I am driving so there isn't that early rev limit.
maxium wrote:hey matt wot afftect will running no speedo sesnor have on the ecu operation?
a freind has a 20vblacktop in a escort race car and is having a few issues getting it to run right
it has a lower rev limit and brings up a warning light
