Anyone here turbo a stock 20v blacktop?
Postby 4000GT » Wed Jul 19, 2006 9:28 pm
I am just curious about the results if anyone has done this here. I understand about the Z engine having lower compression and "better" to turbo etc, not interested. I just want to hear if anyone has done it... obviously a computer is needed etc, lets take those things as a given.
And Phil, no I am not planning on doing this...
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby slighty_sykotic » Wed Jul 19, 2006 10:07 pm
Yes.
If you want to know more, then search.
--Sykotic
slighty_sykotic
Postby 4000GT » Wed Jul 19, 2006 10:43 pm
slighty_sykotic wrote:Yes.
--Sykotic
The search algorithm on this forum is terrible, its easier to ask current owners so further specific questions can be asked. But thanks.
4000GT
Postby z0ton » Wed Jul 19, 2006 11:32 pm
--Sykotic
I totally agree with you. Finding stuff in these forums is a nightmare.
z0ton
Postby Bazda » Wed Jul 19, 2006 11:34 pm
need new plenum.
i would say it will be strong enough for 5psi max or arounds abouts.
Postby Bling » Wed Jul 19, 2006 11:38 pm
learn how to search, its FARKIN easy, if you actually follow the instructions,
Postby Punter » Thu Jul 20, 2006 2:14 pm
BZG|Bling wrote:learn how to search, its FARKIN easy, if you actually follow the instructions,
It is easy if you know the key words in the thread your looking for, ie. you have read it before.
If not its actually not that easy.
But hey, thats just my opinion.
Punter
Postby Dell'Orto » Thu Jul 20, 2006 5:18 pm
Try searching like this:
turbo AND stock AND blacktop....I got 21 matches by doing that.
Amazing how things work when you read the instructions ;)
Postby 4000GT » Thu Jul 20, 2006 6:38 pm
Bazda wrote:need new plenum.
Yeah I know whats needed to turbo it, just looking for peoples results power wise... I will try searching again and see if anyone has dyno charts up, which is what I am really looking for.
4000GT
Postby Al » Thu Jul 20, 2006 6:42 pm
I believe Nick from NZEFI used his turbo setup from his old motor and put it on a stock silvertop 20v in his aw11, he was racing one day when I was at Ruapuna did something like 12.8 @ 108mph.
Al
Postby 4000GT » Thu Jul 20, 2006 6:42 pm
Mmm, Boost wrote:Try searching like this:
I did the same search, seems only one of those was about turbo charging a stock blacktop looking at the headings and that was with the factory ECU and no actual people who have done t seemed to pop up with facts about it powerwise.
4000GT
Postby 4000GT » Thu Jul 20, 2006 6:46 pm
Al wrote:I believe Nick from NZEFI used his turbo setup from his old setup and put it on a stock silvertop 20v in his aw11, he was racing one day when I was at Ruapuna did something like 12.8 @ 108mph.
Hmmm I forgot about Nicks engine, I should have remembered since he is my flatmate and drove that car a bit before it took up smoking 2 packs a day lol I will have to ask him more when he comes back from holiday...
4000GT
Postby matt dunn » Thu Jul 20, 2006 8:59 pm
That was a silvertop bottom end which had the ok rods in it etc.
Will make more power than a tru blacktop would safely.
Postby 4000GT » Thu Jul 20, 2006 11:11 pm
You doing the speed event Saturday night Matt?
4000GT
Postby matt dunn » Thu Jul 20, 2006 11:23 pm
This Saturday? Know nothing about it.
I take it is in CHCH?
Matt
Postby crnkin » Thu Jul 20, 2006 11:28 pm
Al wrote:I believe Nick from NZEFI used his turbo setup from his old motor and put it on a stock silvertop 20v in his aw11, he was racing one day when I was at Ruapuna did something like 12.8 @ 108mph.
And wasnt that on race fuel/ avgas mixture?
Was in an early rev mag, 170kw atw with ht18 i think, on 18psi, stock silvertop.
And the difference in compression is huge, id put my dollar on it blowing awful quick. less than 2000km's maybe
deaf_homo "currrently yes"
crnkin
Postby 4000GT » Fri Jul 21, 2006 8:14 am
matt dunn wrote:This Saturday? Know nothing about it.
Matt
Yup
4000GT
Postby Lanius » Fri Jul 21, 2006 9:52 am
CircuitLevin wrote:I did the same search, seems only one of those was about turbo charging a stock blacktop looking at the headings and that was with the factory ECU and no actual people who have done t seemed to pop up with facts about it powerwise.
If you state that you've already searched and it didn't produce the results you wanted, people are less likely to ask you to use the search function :wink:
Lanius
Postby 4000GT » Fri Jul 21, 2006 5:37 pm
Well, people actually stated there was info by doing searches, but even that didnt provide any valid results! People may be too quick to pull the search call :)
4000GT
Postby Lanius » Fri Jul 21, 2006 10:29 pm
Fair enough ... in this case, you're obviously after specifics which weren't available in the threads found in search. I'm sure you can appreciate how frequently questions are posted that have been asked and answered many, many times in the past.
Hope someone can point you in the direction of the info you're after :)
Lanius
